Question about Danze Plumbing
I have a Danze model #4565-13-ss Melrose Pull-Out. The finish on the handle wore out and I purchased a new one to replace. I believe I need a hex wrench to fit the set screw - what size is it, and is it US or Metric? NYOESSUPPLIES@AOL.COM
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
2.5mm is the correct size, but you can use a 3/32nd inch if have to.
Posted on Sep 06, 2010
Leaking pull out spout
Usually, it is caused by a worn out o-ring.
Jan 31, 2014 | Danze D403412 Melrose Single Handle...
Leaky danze shower faucet
you need to go to lowes or your nearest plumbing supply store and get a new cartridge and replace...you may also just be able to replace springs and seats if its like a delta...i believe danze is made by delta...ask them for help and they will advise you on parts...good luck...remember to shut water off to home before doing this repair...
Oct 17, 2012 | Danze D500511BN Brushed Nickel Melrose??...
How to pull the lever off the top
There is a set screw under the handle lever maybe covered with a small cap or bottom type cover. remove that cover if it's still there and loosen the set screw and pull the handle off.
Feb 12, 2011 | Danze D403412 Melrose Single Handle...
Lever won't stay on at low flow rate; lever closes automatically. What can I do to fix it?
Sounds like the retaining ring under the handle may need to tighten a little to stiffen lever a little. To remove handle take plastic red/blue cap at base of lever covering the screw. Remove allen screw that holds handle to base with a allen wrench.
Try to tighten collar that holds the stem for the lever and that should help with the lever. if not the gasket that's under the collar maybe wore to the point that tightening want effect it.
If you need a parts diagram go to this link for an exploded view of the internal parts. I hope this will be helpful to you.
http://www.needplumbingsupplies.com/Danze/Specs/D403412_Inst.pdf page 4 has a breakdown.
Dec 29, 2010 | Danze D403412 Melrose Single Handle...
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Nov 09, 2010 | Danze D403412 Melrose Single Handle...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
REMOVAL OF CARTRIDGE
Good morning! please check the top portion of the faucet if there's plastic covering which we have to pull it off to see the screw lock of the cartridge, then unscrew the cartridge lock counterclockwise. best regards.
May 05, 2009 | Danze D403412 Melrose Single Handle...
I have a single handle kitchen faucet that now has no cold water
You need to install a new cartridge in the faucet.  The cartridge controls everything.
Mar 09, 2009 | Danze D403412 Melrose Single Handle...
Plumbing Logo
223 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
