Printer malfunctioned and now says it has no driver
It is a printer scanner,and copy machine. But the printer has stopped working.
How I fixed it? Well I threw it in the garbage.
Posted on May 12, 2008
My HP Envy 5530 will copy and print but won't scan. How can I fix it?
Make sure there is a scanner driver loaded in your computer. The printer driver only will not work the scanner
Jan 27, 2016 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
This is driving me mad! I had a canon mp150 and the scanner stopped working! After a lot of messing around i thought i'd just buy another printer as i thought the problem might just be the mp150...
Download and install the latest driver for your printer from Canon. Install the driver first, connect the printer to the computer using a different USB port than you usually use for the printer, then restart your computer.
Feb 28, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Printer works, scanner/copy does not
The problem could be because of ONE out of TWO problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 24, 2010 | Dell 924 All-in-One InkJet Printer
Scanner malfunction
JTuohey
I had the same problem and just successfully repaired. Uninstall driver and reinstall. Worked perfectly!! Good Luck!!
Jun 23, 2008 | Dell A960 All-In-One InkJet Printer
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Scanner quit working
the scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software. You can check the hardware simply by copying a page. If you can copy there is no hardware prob. Post here again if it does not work and let me know your windows version, too, please.
Sep 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer will not copy or scan but will print
Hi John, Even if you have deleted them by accident, you can always reinstall using the CD that came with the printer/scanner. If you want to do a clean install, then you would probably have to uninstall also the printer drivers and start from scratch. You may also not uninstall and set it up again. If you go this route, it is also possible that you will have two icons in your printer folder of the same hp printer. Assuming nothing is wrong with the hp, the scanner drivers and app would be reinstalled and presumably you will have access now to your copy/scan functions. Should like to download the installer/driver for you printer/scanner, it is available at (http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&product=79488&lc=en&jumpid=reg_R1002_USEN). You would have to select your operating system. Hope this works for you. Pls post again how things turn up. Kind regards.
May 29, 2007 | HP PSC 2110 Color Printer
Cannon scanner D1250U2F and Hp photosmart printer 8250
This is a compatibility issue between the Copy function of Toolbox and the specific HP printer driver. The only work-around would be to scan your image and save it, then print it from another application. One other possibility would be to get Toolbox version 2.2.x from the N650U scanner download page. This version will be limited in functionality, but COPY button should function as expected.
Apr 28, 2007 | Canon CanoScan D1250U2 Flatbed Scanner
35 people viewed this question
k24674
jasbo
jasbo
