Question about Brother HL 1440 Laser Printer
I get 4 horizontal lines evenly spaced acroos page I was told there was a utility program to automatically align the heads.If true, I don't have the disc . Where do i get it, how do I fix the problem?
  • 1,110 Answers
There are no "print heads" in this machine. Whomever told you that was wrong. If you are getting fuzzy horizontal bands across the prints then this is coming from the drum unit. I have seen this so many times it is not funny. Just order a new drum unit. Take your existing toner cartridge out of the old drum unit and install it in the new one and you are all fixed.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
How do I align heads on my Canon MG2200
Step 1 Ensure the printer and computer are turned on and connected.
Step 2 Locate the printer utility program by clicking on the printer's desktop icon if present. If it is not, click Start and type the printer make or model into the search box. When the printer utility program is displayed, click the program name to open the utility dialog box.
Step 3 Locate the "Maintenance" tab at the top of the printer dialog box and click to view contents. If the tab cannot be found, the maintenance screen can be accessed by clicking on various buttons (Advanced, Tools or Properties) and subsequently searching the dialog boxes to locate the maintenance button or tab.
Step 4 Click "Align Print Heads" or a similarly-phrased button.
Step 5 Click "Print Alignment Page" to yield a test page printed with a numbered series of vertical bars in various colors. Click "OK" or "Finished" to open the next instructional dialog box.
Step 6 Inspect the page, choosing bars from each color group with the sharpest image, and enter the corresponding numbers into the text fields for each color. Click "OK" or "Finished" to begin the automated alignment procedure. The printer adjusts cartridges based on the numbers you've entered. When the process is completed, you may click "Finish" to close the window and process, or print a test page featuring detailed shapes and lines of varying colors to further inspect. Click "Finish" to exit or "Repeat Alignment" to further adjust cartridges.
Jan 31, 2015 | Canon Office Equipment & Supplies
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Printer printing horizontal blue lines across the page. lines are spaced apprx 1 inch apart have aligned, cleaned and recalibrated printhead but problem still occurs
Program malfunction, uninstall HP Printer programe and reinstall your version for the printer from www.hp.com remember to load the complete program.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Mar 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Horizontal white lines
Go to the maintenance link for your printer (in properties) and clean your nozzles. It could be this, bad or low ink or needs alignment.
Dec 16, 2008 | Lexmark P6250 All-In-One InkJet Photo...
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Brother HL 1440 Laser Printer Logo
385 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
