Question about Cycling
I have a lifestyler 3500 ergometer bike that is new to me, and after moving it seems frozen. It worked before moving. Now it will not pedal or arms won't work. would having placed it on it's side have caused this or do you have any suggestions?
3 Suggested Answers
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
  • 1788 Answers
SOURCE: My son has the Huffy
The reason the pedal fell of is because of a bad set up. Who assembled the bike? If, you did, guess what! You did not tighten the pedal to the crank arm to begin with. If, Walmart or other discount store did it, have them fix it. You have to understand. you bought the bike without professionals putting it together and sometimes that is a problem when you don't have the knowledge of what you are doing. You have to pay one way or another. When you let a kid ride a bike that is not assembled correctly you are endangering them. My advice is :Get it fixed right.
Posted on Sep 16, 2010
My Tunturi home bike I purchased in the 80s' makes noise while pedalling.
My Tunturi ergometer was squealing like a pig in heat. My husband removed the speedometer and it is wonderfully quiet. I do not use the speedometer anyways - it is like new!!
Sep 20, 2010 | Tunturi Cycling
Where can iget info on ergometer
Never heard of a ergometer for a bicycle. You understand that an ergometer measures the workload, so you would have one on an exercise bike, or a bicycle trainer. There bicycle accessories, like a cyclecomputer, and you can wear a heart rate monitor. Go to a bike shop that sells fitness and bikes, they can hook you up.
Sep 17, 2010 | Cycling
My bike does not seem to shift gears should I be cruising as I shift or should I be pedaling
Your bike must not be the Cruiser pictured - that's a one-speed bike. So here's a general description--- For gear changes on multi-speed bikes, where the chain has to move between different size sprockets, the chain must be moving in order to shift. So, yes, you have to be pedaling, but it works best if you pedal very lightly - so that the chain is moving, but is under very light pressure. On the other hand, if you have a 3-speed bike where the gear changes take place inside the hub of the rear wheel, the wheel should be moving, but the chain should not - so you should be coasting to change gears.
Jun 23, 2010 | John Deere Nirve Model Cruiser Bike
No change in resistance
IF you have the one i have, there is a knob with two connected arrows and a plus and minus sign. turn toward the plus, more resistance, turn toward the minus, less resistance.
Feb 04, 2010 | Tunturi E30 Ergonomic Exercise Bike
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
Have need parts to a tunturi ergometer / exercise bike
It looks like the only cable FitnessRepairParts has for Tunturi Ergometers is a speedometer cable for serial numbers greater than 474100.
Aug 26, 2009 | Tunturi Cycling
I need new brakes on my resistance caliper
You can probably replace them with regular bike break shoes.  If it is easy to remove them just take them to a bike shop (not a large chain store) and see if they can help.
Dec 22, 2008 | Tunturi Cycling
Cycling Logo
218 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
