Question about Delfield Refrigerators
Im looking for the specs on a Delfield cold table 4048-12 I have fornd the -8 but need the -12 for county paper work on a resterant
Urc-6011b00 one for all remote set up codes for Emerson tv for tv input channel..my god is it sooo
01 5 4 ,0 2 3 6 ,0 4 6 3 , 0 1 8 0 ,0 1 7 8 ,0 1 7 9 ,0 0 1 9 , 0 6 2 3 ,
0 6 2 4 are the codes i fornd for your tv
Oct 03, 2015 | One For All Televison & Video
Replaced starting components (relay was burned out). Compressor starts and runs ok but only for about 15 seconds then cycles off by the t-stat. Starts again in about 45 seconds and shuts down again. ...
Ok so in this case the most likely reason the relay burnt out is because the compressor is tight and having problems starting so it burnt relay. Need to determine what LRA (locked rotor amps) is by looking on data plate on compressor and see if amp draw is at or very near the LRA spec. if it is the compressor is bad
Aug 12, 2011 | Delfield Refrigerators
Delfield vs bev air, which way would you go for a used 2 door under the counter refrigerator in a concession trailer?
I'm not a big fan of either. I've been involved in the restaurant business my entire adult life and neither one impresses me. If I had to choose, it would be the Delfield but keep in mind that their parts have to come from a Delfield supplier. Bev-Air parts are a little easier to get except for things like door hinges and door gaskets. Sorry that I can't really be much more help than this but this is my opinion based on experiences.
Feb 07, 2011 | Delfield 64'' Refrigerated Sandwich Table...
Delfield 6000xl: what is the 404a freon charge?
http://www.delfield.com/docs/uploaded/del/Serviceinfo/ref_serv.pdf
this web site has a table of units and their respective charging amounts.
Hope this does it for you.
May 09, 2010 | Freezers
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
this is for their web site. It has all the manuals and charging tables. There is no 6000xl. Need exact model number as the amount varies.
Hope this helps
Mar 25, 2010 | Freezers
The refrigerator has been running since we plugged
I think it needs replacing. In some cases, the thermometer is actually the front of the controller of the unit. This could be why it runs constantly. I would also look at the condenser coils and make sure they are really clean.
let's start there. let me know if I can help further.
Jun 14, 2009 | Delfield DEL-SSR3S Spec Line 3 door...
Data From Table Auto Fill
You need to create 2 tables. Create one table with just the Center Number, County and Center fields, using the Center Number as the primary key, lets call this table Center. Then create the other table with all the other fields you need, lets just call it the Main table for now.
Then create a relationship between the Center table and the Main table using the Center Number for the relationship. The relationship should be a One-to-Many from the Main to teh Center table. When creating the form, you take the fields from both tables. When you input the Center Number, the County and Center should be automatically filled in.
Apr 08, 2009 | Microsoft Office Access 2003 (077-02871)...
Delfield model st4660n 2door cooler no cold air
sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Dec 09, 2008 | Delfield 60 Refrigerated Work Top Model...
Refrigerators Logo
42 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
