I have red color behind words people on screen, blurry screen, like things don't line up.
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.Very common problems on DLP projection tv.R,G,B colors lines mis alignment,colors shadows and 3D pictures.The problems is the convergence board parts the 2 STK convergence ICS and some or all of it resistors are dead.These parts must be replaced on the convergencce board to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Sep 03, 2010
Blurry screen. The words are shown in double behind each other red and yellow on top of screen.
im guessing on this one.....Try adjusting the color selectors,might be distorting words.
Nov 28, 2012 | Televison & Video
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
There is too much red in the television
your red convergence circuit is defective and requires attention
Apr 28, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
HCL4715W Rear projection blurry
The focus controls on this set are in the front behind the bezel. I'm not sure, but, I think on this age of Samsung, the screws to the front bezel are on the back side of the set. After removing the screws from the back, the front bezel snaps off and the door behind the bezel need to be removed. Watch the wires connected to the bezel, they need to be attached in order to turn on the set. The focus controls are on a black control block (there are three of them, one for each color). Adjust each color for sharpest picture. I use words on the screen for alignment. Each CRT board has a screen control (Adjust each slowly until retrace lines appear on the screen and then back off until they disappear). You may turn off the color and make sure that the picture is black and white. If it is not, then, which ever color is dominant, back it off a bit with that screen control. Facing the set, Red is left, Green is middle and Blue is on the right. Use only one hand inside an operating television. Do not touch the board, just the controls. This concludes television alignment 101. Any questions respond to this post and I'll reply.
Aug 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
467 people viewed this question
Top Televison & Video Experts
