Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Posted on Nov 04, 2010
  • 3 more comments
  • gwhizofto Nov 27, 2010
    Hi, actually, you don't even have to unscrew the central screw! Just gently pry up on the lower spool edge.
  • kingmidas_00 May 25, 2011
    Nice. Great tip! Thank you.
  • Linda Hogan Sep 23, 2011
    Thank you, thank you. It took me two days, and then after finding your comments it took me less than 5 minutes.
  • mtaherkhah
    mtaherkhah May 20, 2012
    Just be sure to pull the spool straight out -- shouldn't require turning at all, and it may take a bit of a pull to get it off, dependingg on how dirty it is.
  • mtaherkhah
    Actually, we struggle every time so I've finally documented it (instructions aren't clear from B&D). Once you've removed the orange spool cover, you should be able to just place your fingers in the indents on the top of the spool and just pull (it may take a bit of envergy) straight out to remove the spool. No need to turn at all, since turning should ONLY be for when you replace the spool back in the trimmer housing (til it clicks in place). It's simply pull straight out - that's it!
The line on the B & D Electric Weed Eater has broken off. I can take the Orange cover off, but I do not know how to get the spool so I can continue weed eating.
Not avoiding the answer but if you google (" re-string a weed wacker video?" ), you can watch a video of how to do it, which may be a lot easier to understand when you see it.
Jun 30, 2011 | Black & Decker Vacuums
Black and Decker grass hog GH1000 Which dual line replacement Spool do I need?
If you are replacing the entire spool,then any that will fit on the end of the weed eater will work.
Jun 29, 2011 | Garden
I need to know how to re-string my black & decker weed eater
Here is the instruction manual direct from Black & Decker for the GH1000 XP model. You may or may not have the twin string head, but all instruction manuals are available from their site. As close as I can figure, this pertains to your model.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90556296,GH1000.pdf
You will need Adobe Reader installed on your computer to view this as it is a PDF. If you don't, go to Adobe's website. The download for it is safe and free..and easy to delete afterwards if unwanted.
Apr 03, 2011 | Black & Decker 14" Grass Hog Xp...
GH1000 Motor runs but spool just quit working.this is electric.
Same thing happened to me. The belt broke. You'll need to take off all the screws to change the belt. There's a hidden screw under the black label. Feel around for the soft spot.
May 21, 2010 | Black & Decker 14" Grass Hog Xp...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Black and decker 110 volt grasshog
The last time I used the weed wacker it kept stopping-almost like a short. The battery is fully charged and has a lot of power when working. Would the problem be in the handle and can that be taken apart to see if there is a loose wire?
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
2,133 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
