Whirlpool Quiet Wash II - LSQ9010PW2 Machine works great but intermittently does not completely spin for larger loads. Seems like something is slipping.
  • Washing Mach... Master
  • 2,180 Answers
You can check the motor coupling to see if it's rounded in the middle and check to see if there's any oil on the floor or around the tranny,you can slide the washer forwards around 12 inches and tilt it back and rest it against the wall and check with your hand to see if you can feel any oil on the tranny,or use a paper towel to check it.if it's the tranny you'll have to decide if you want to sink 300 bucks into this washer or buy a new one.let me know what you find.the coupling is behind the motor,pop off the two metal clips on the pump and slide it off the motor shaft,remove the two screws and clips on the motor and slide that out and you'll see the coupling on the back of the motor and the other half of the coupling will be on the tranny
Posted on Sep 04, 2010
Will not spin clothes
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't switch from wash to spin...
You have a bad motor. Your motor turns in one direction to wash and the other to spin. One directions windings are bad. This is why it is drawing currant so bad. Sorry, seems I'm always the bearer of bad news.
Please rate solution
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Where are the fuses to the water pump
Hi there......the water pump does not have a fuse...it is not controled by a fuse....it is controlled by the programmer....the whole machine is protected by a fuse in the plug top...water pumps or drain pumps usually suffer from a damaged impeller...or damaged coil windings...either of would require you to relace the pump
regards Sir Galahad
Aug 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but will not actually wash
the most common thing here is what they call a reverse/forward module
it makes the machine wash both directions
if you don't know anything about washer repairs then may i suggest that you get someone else to look at it
Jun 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
192 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
