Question about Weber SPIRIT E-210 (NG)
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just not high enough to really get the grill hot enough to sear a steak.
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
Grill doesn't heat to high temperature.
try cleaning the injectors they could be blocked
Aug 13, 2012 | Ducane 30400040 Stainless Steel Grill
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
It will only heat to 350 degrees, but the gage goes up to 700 degrees. In other words, how high can you get the temperature to with all burners on high? Thanks, Ron
LP or NG, all burners on high, top closed, out of the high winds (if any) 500+ degrees in 10 - 15 minutes. If not, double check temperture with a secondatry temperture device. If it an old unit, could be gas lines partially cloged. What size of flames come off of the burnes and what are the colors (AT THE BURNER, IN THE MIDDLE OF FLAME, AND AT THE TIP OF THE FLAME.). The olors will indicate the gas / oxyen mixture and therfore heating efficency and templture.)
Yellow is lowest - flame tip light blue almost imvisible is hotest.
Apr 16, 2010 | Char-Broil Commercial Stainless Steel...
When the grill is on high heat for all 3 burners only heats up to
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 05, 2010 | Weber Genesis Silver B Grill
Oven powers up but doesn't heat
When you turn the control to 350 or so the bottom heating element should heat up, if it don't, turn the control to broil if the top element heats up it is most likely the bottom element has burnt out and need replacing. You can find the elements at Home Depot or Lowes, if not in stock at the store, you can order it inside the store.
Feb 13, 2010 | Ovens
Heats only to about 350 degrees
how old is it may neet to clean and blow out burners
May 25, 2009 | Char-Broil Performance 463463006
Grill not getting hot, fire not around burners, knobs are so hot you can't touch them. not getting over 300 degrees, fire seems to be behind knobs
We assembled our new Genesis E-310 yesterday. Went together nicely, but won't heat above 350 or so. It should get to 500-550 degrees withing 10-15 mins. Any ideas of what could be wrong?
May 11, 2009 | Grilling
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
Low output
The grill is not staying lite and not heating up like it should.
Jul 03, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Weber SPIRIT E-210 (NG) Logo
886 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
