Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The extra large mop head attachment will not release steam. It seems to be clogged, and the steam escapes above the head attachment. How can this be resolved?
  • Euro-Pro Master
  • 43,501 Answers
I saw this post, so I had to go and checkout my wife's shark....
If you pull the attachment off and look inside you will see that there is a small hole that the steam travels through into the flexible hose with the spring around it and then on to the head and out the smaller holes...
Now if the first hole gets plugged then no steam will get through to the head...however if there is something stuck in the hose or the smaller holes in the head are plugged it still could act the same...
So, first look right inside and check that out, then if that is okay, take out the four screws that hold the swivel into the head...then you can take out the last two screws holding the swivel to the head...
This will allow you to blow back through the hose to make sure it is not obstructed or to blow the dirt back out...
If that is open the take a tooth pick or some small like that and open the holes in the head....blow through the head to make sure that they are open and then replace everything back like it came apart...
Now the steam should be going out the head like it was intended...
heatman101
Posted on Sep 03, 2010
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
Sounds like there may be a clog? i know of a site that sells the heads cheap BNTPrice
i hope this helps
Posted on Nov 15, 2012
Shark steam mop not sending steam to attachment
It sounds like the head could be clogged up. Try running water in the head and see if that works
Jun 07, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam pocket mop seems clogged. Steam does not come out of the mop head. The clog appears to be in the rectangular mop head. The triangular head still works fine. I've tried soaking it in hot water...
I had the same issue with the rectangular mop and corrected it by disassembling the tube from the rectangular piece. There are two screws that will need to be removed in order to get access to the connector. Once the connector is removed from the rectangular piece you will need to **** out the clog. I used a small drill bit and was able to do this without attaching the bit to a drill. There is a slight angle to the connector which causes the clog to occur. The total job took about 45 minutes to accomplish. I could have purchased a replacement for $21.95 but thought I'd take a shot at fixing it. Hope this helps.
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a shark steam mop s3202 and it seems to be clogged - no steam. I hear if you put white vinegar in it it should help unclog it. Are you suppose to let it sit awhile. Should it be plugged in?
Yes, plug it in...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Shark Steam Mop S3501CO model. When I press the release button to exchange mop heads, the mop head does not release. Nils Friis
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That head can stick very tight...get someone to hold the head and you pull the mop...
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Aug 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark seems to be clogged, and steam will not come out. I know that it is making steam due to the pressure, but it will not come out of the mop part. How can I clean it to get the mineral deposits out?
heatman101
Jul 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need video or large diagram instructions for what to put together
heatman101
ui
May 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark is leaking where the head attaches.
heatman101
Feb 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
497 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
