Question about Mitsubishi VS-60609 60" Rear Projection Television
What year are the mitsubishi VS 60609 - Mitsubishi VS-60609 60" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
It is a 2001 year model and will have the exact production month and year on the back some where.
SD TECH
Posted on Sep 03, 2010
  • 10,594 Answers
VS-60609 is VZ9 chassis made in 2001
4 Suggested Answers
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
Posted on Oct 09, 2007
freetek
  • 5568 Answers
SOURCE: No power on 2002 Mitsubishi VS-60609
You've mad the right decison; fuses can fail due to metal fatigue as they flex a little each time current flows through them of ceases but a 2nd fuse is unlikely to fail instantly. This indicates a true problem.
If you found the fuse, it was probably located on the main power supply board and this item has likely failed.
Look for an assembly number on that board and call a Mitsu service company and inquire about repair or replacement cost. Either one can range from ~$75 to $150.
It would be interesting to know if the fuse blew as soon as the unit was plugged back in or only when you tried to turn it on with the remote or power button on the set.
If it blew only by plugging it in, that power board is the culprit. If it blew as you tried to turn it on, it could be a failed 2nd power supply for the CRTs that is often located separate from the main supply where the fuse was.
About any E-tech could ferret out the which of the two is at fault so you might consider having a pro do the repair but if you know the failure sequence you might choose to gamble on making the decision yourself.
Good luck-
Posted on Jun 19, 2009
maatmartin7
  • 1229 Answers
SOURCE: i have a mitsubishi 60inch
You will need to replace IC8c00 (STK 393-110) . This is your convergence IC. You will need to measure all of the 6.8 ohm resistors, replace as necessary. These resistors will have blue,gray and gold stripes, there may be sixteen of these. Expect to replace at least three of these if not more. Replace caps C8c05 (25 volts at 100Mf),C8c07 (25 volts at 100Mf). Other caps to replace are C2c86 (25 volt at 10Mf),C2V17 (25 volt at 10 MF) and C601 (350 volt at 1 Mf). you will also need a keen eye to resolder connections behind tuner TU1A02 (says RF). Jumper sockets CE,RG,DM,VU,DP,EL. Check and resolder socket connections KC,KB,AV1,AV2 and resolder IC 2p30. And you will also need to pull the power supply board, resolder jumper connections CE, RG, DM, VU, DP, and EL. Resolder the vertical IC , this IC will be of the LA78XX series,(do not use excess solder and short the pins). Resolder the horizontal transformer, and the flyback transformer. You will need a keen eye to visually inspect bad grounds on power resistors,horizontal transistor, horizontal output transistor any any and all regulator transistors located on heat sinks. This may seem complicated, time and patience will repair this. Spend an hour a day for two weeks to fix this. Thanks for asking and show all hands of support!
Posted on Jun 01, 2011
Testimonial: "thank you for the info. its the best i have gotten. :) "
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Program vs-60609 for cable
no need to register on this link :http://safemanuals.com/annexe_Owners%20Guide_MITSUBISHI_VS-60609-_E.htm
cheers
Dec 23, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Where do I find a screen and mirror
Hello jeremyv,
I would suggest calling Mitsubishi Technical support, they might be able to help you in this ares.
Thank you,
Shuttle83
Dec 21, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS 60609 60 inch
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: varo9@hotmail.com Thanks!!!
Oct 16, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
