Question about Whirlpool MH1140XM Microwave Oven
Light won't turn off, microwave won't work
For no apparent reason, my Whirlpool MH1140XM microwave has stopped working. The interior light will not turn off. I am able to push all the buttons (ie the screen works) but when I hit start to warm something up, I get only three beeps. The timer and everything else works, though. I shut off the electricity to the microwave to no avail. This was all very sudden. Please help!
  • idealmaids May 11, 2010
    My whirlpool light won't turn off and it stopped working.
    It's over the range microwave. If it's the door switch that is stuck open how do I fix it?
  • 1,554 Answers
The door switch is likely stuck open.
Posted on May 12, 2008
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
Eveything works except it heating the food. nh114dxm900watts micowave oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,,./
Jul 13, 2011 | Whirlpool MH1140XM Microwave Oven
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
My whirlpool mh 1140 xm microwave/ hood combo is not heating. everything else works fine, just the heat. I would rather repair than replace. Help!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 08, 2011 | Whirlpool MH1140XM Microwave Oven
Replaced lower light. It flashed. Now the light
With this model you should unplug it first. More than likely it is a burnt track/trace on the controller board between the relay and the header going to the light. Easy to fix if you have a soldering iron, short piece of solid wire etc. Accessible from the front, just take off the top grille and then the one screw for the control panel.
Jul 02, 2009 | Whirlpool MH1140XM Microwave Oven
Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
May 11, 2009 | Whirlpool MH1140XM Microwave Oven
Microwave stopped working for no reason
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 21, 2008 | Whirlpool MH1140XM Microwave Oven
Microwave stopped working suddenly
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
Aug 27, 2008 | Microwave Ovens
Help!! I was cleaning my microhood
Sounds like you will either need a new membrane, or pcb.
Jun 28, 2007 | Kenmore 80809 Microwave Oven
Whirlpool MH1140XM Microwave Oven Logo
400 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
