Question about Traxxas Rc Revo Nitro Monster Truck
My revo 3.3 will not go...it starts and revs up but the tires barely spin...can anyone help?
2 Suggested Answers
  • 56 Answers
SOURCE: traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
Posted on May 30, 2010
Traxxas revo 2.5r
the engine shutt down just if load and not bobtail
Dec 29, 2013 | Traxxas Rc Revo Nitro Monster Truck
My kx 80 (1992) starts and revs up nice but wen put into gear it hardly moves, the heavyer the person trying to ride it the less it goes, when I lift the back wheel off the floor (no pressure on engine)...
Front wheel drag (locked brake).Bad tire air pressure.If not,is carburetor cloged,need to drain (bolt under) or remove to clean.If the motor revs in the gear ,the clutch slip.Could be bad clutch cable tension or need replace clutch/cable.
Oct 22, 2013 | Cars & Trucks
I have a 2005 ford mustang. it easily spins when i barely get on the gas pedal. what can i do?
it sounds like your tires are spinning when you accelerate quickly.Check the condition of your tires. check air pressure. It should be on the door or in your owners manuel, if this is not the problem check tire size with owners manuel. if none of the above is your problem look for a set of new tires made from a softer rubber with more gripping power if this was at all helpful please leave me good feedback.
Apr 01, 2013 | 2005 Ford Mustang
When I start the washer it just barely washes the cloths....When it goes to the spin cycle it wont drain and barely spins...then I'll stop and start it 2 or 3 times...It will then finally drain the...
It sounds like you belt is the problem, if it is glazed or stretched this will happen. The part number is 21352320, below is a link if you wish to order one.
It is located under the unit and goes around all three pulley's. Inspect the motor pulley closely, if melted or damaged you may need to replace that also.
Belt www.repairclinic.com/PartDetail/Belt-Drive/21352320/1318
Motor pulley The pulley is available but when I looked it up it changes to a complete motor, part number for just the pulley is 21001506
Good Luck
Aug 14, 2011 | Maytag PAV2300 Top Load Washer
The motor on our brand new Revo 3 Wheel makes a ticking noise about every revolution of the wheels. This is our second Revo, the company exchanged the first one due to the same problem that they could not...
Trent I had this with another scooter and it turned out to be a cut or piece missing from one of the tires. Check all the tires carefully for any little defect or gouge. If you find something fishy take a piece of tape and cove the defect and the drive the scooter and see if you still hear the ticking sound. If that doesn't help block the rear of the scooter off the floor and have your wife run it slowly carefully listen to both rear tires to see if you can find the one making noise. If you can't hear the noise block up the front tires spin them to listen for the sound you are hearing. Hope this helps and let me know what you find Good Luck
Oct 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
Traxxas revo 3.3 running problems
May 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
Transmission slipping on traxxes nitro rustler
i think the slipper cluch has become wore out from the sudden jam up of the wheele.
Apr 18, 2010 | Traxxas E-revo Rtr Racing Monster Truck
Do all new Revo scooters come with newer low
SORRY,BUT THEY CAN'T BE CHANGED BUT ON UP SIDE THESE R SMOOTHER
Jul 15, 2009 | Pride Value Line Revo Scooter 3 Wheel
Troble with clutch
Its probably the spur gear. I had that happen a lot of times :)
Apr 19, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
287 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
