Question about Sunbeam Healthometer Body Fat and Weight Scale Stainless Steel
I keep getting e on scale dont know what i did wrong setting it up Model bfm884dqn-60 it is for 4 users height of 5 3 1/2 is displayed pls HELP Thanks
I think that those numbers are for the spacing of the feet? I'm not sure what that number is, but anyway you have to push select 3 times and it will save and then the scale will zero out. After that you can push one of the four buttons and program you height/age/gender. I think they really made this scale kind of user difficult.
Posted on Feb 05, 2011
I have a healthometer BFM920KD-01 scale and
Just push either the #"1" or "2" user button and hold it down. The display will flash the height numbers. Hit the Up or Down arrow to change the flashing "5" to a six, etc. Then hit the "set" button to "enter" your choice. This advances the display so that you can now change the inches, gender and age. You're good to go!
Apr 14, 2012 | Health-O-Meter Health o Meter BFM588DQ-81...
How do I change the age on my healthometer scale, model BFM676KD01
Press Left "Select" key; Press Right "Scroll" Key to select USER (Digital Display flashes to show USER #); Press and HOLD "Select" Key until "Height" flashes; Press "Scroll" to advance Height '; Press "Select" to move to next input. When "Age" flashes, press "Scroll" to your age, and you're done!
Nov 17, 2011 | Health & Beauty
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Apr 08, 2009 | Health & Beauty
How to utilize the WW87 Glass Body Analysis Scale?
I discovered that it helps if your feet are slightly damp. I usually wipe them with a washcloth before getting on the scale. They don't have to be WET, just every so slightly damp.
Dec 20, 2008 | Conair Weight Watchers WW-87 Body Fat...
Changing user settings on Conair WW67T scale
1. Tap the scale
2. Wait for "0.0" display
3. Set
4. Use the up arrow then stop on the user you desire
5. Set
6 Using the up/down keys enter Height
7 Set
8 Using the up/down keys enter Age
9 Set
10 pick the little man or woman
11. Press SET - the scales will redisplay your profile settings for verification.
12. Wait Until the Display Goes Blank.
13. Tap the Scale.
14. Press USER, select desired profile, P-01 is the default.
15. Wait for "0.0" display
16. Step onto the scales and wait for all measurements to display
Oct 02, 2008 | Health & Beauty
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Sunbeam Healthometer Body Fat and Weight Scale Stainless Steel Logo
473 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
musquodoboit
musquodoboit
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
