How do I download a program into the flash drive and remove original program from computor
    Problem Solver:
  • 18 Answers
When you asked to save the program save it into the flash drive directly then delete the old one
Posted on Sep 04, 2010
How to transfer internal memory pictures to computor
You have two options:
1) Remove your memory card from the camera, if you have one. Then connect the camera to your computer using the supplied USB cable.
2) Use the "Copy" command in the Playback menu to copy the pictures from the internal memory and then download the pictures from the memory card. Once the card is plugged into a card reader attached to your computer, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
If you need a manual, you may download a copy from here.
Sep 16, 2012 | Nikon Coolpix S9100 S-9100 26248 Black Hd...
When I download pis to computor it tells me /error
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 05, 2012 | FUJIFILM Finepix S2100HD Digital Camera
How can I flash my xbox 360? it wont recognize the new dvd rom drive.
Disconnect all cables from the Xbox 360 and remove the faceplate from the front of the console. Lift the plastic tabs on the outer shell and remove the plastic casing from the machine. Unscrew the Torx size 7 screws and lift open the metal cover. Unplug both the power and SATA cables from the rear of the DVD drive and lift it out of the console. Replace it with the new DVD drive, and connect the power cable to the unit. Connect your SATA cable to the DVD drive and a free SATA port on your computer.Turn on your computer and open a web browser. Download JungleFlasher and run the program. As of September 2010, JungleFlasher is the most stable and up-to-date flashing program for Xbox 360, and it is also the only program capable of flashing Xbox 360 drives from within Windows (earlier programs used MS-DOS). Click "Flash .BIN to DVD" in the program's main menu and select your Xbox 360's DVD drive. The program will flash the new DVD drive for use with your Xbox 360 console.Turn off the computer once the flashing process is complete and disconnect your SATA cable from the DVD drive and your PC. Reconnect the Xbox 360 SATA cable to the new DVD drive, then close the metal cover on the console. Rescrew the Torx size 7 screws and replace the outer plastic shell on the Xbox 360. Return the faceplate to its original position then reconnect all external cables and accessories to the console. Power on the Xbox 360 and the replacement DVD drive will function normally.
Feb 27, 2011 | Video Game Consoles & Games
How do i downloag music stored on a file in the computor to my card to put in my phone. I put the card in the computor and it dont tell how to use it
first insert your card to computer, use card reader your card will show as removable disk
if the card was show, open windows explorer, search music that you wan to download to card
select the music file that you want to insert to card
right at file that you select then click copy
after that go to removable disk drive, open it, open the folder music/sound
at that folder right click and click at paste
and you done the process download from computer to card
eject your card from your computer
insert your card to the phone and you canplay music at your phone
i hope this helpful
thank you for using fixya
Feb 07, 2011 | SanDisk 2GB microSD Memory Card
How can i get my camera that i bought at a pawn shop to down load on my computor with out the soft ware? i don't have the disk from the camera to down load on my computor.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 28, 2010 | HP Photosmart 433 Digital Camera
Where can I get CD for Canon A560.Lost Original, I need so I can set up computor and load pictures from my camera to the PC. Thank You Frank Moorhead
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Nov 26, 2010 | Canon PowerShot A560 Digital Camera
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Will not download pictures,to computor
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Apr 05, 2009 | Nikon Coolpix L11 Digital Camera
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
