Question about Saeco Coffee Makers & Espresso Machines
My Saeco Magic Comfort Plus machine will not grind the beans. The grinder just spins and spins
  • Saeco Master
  • 1,711 Answers
You can try to remove all beens, then with the use of paint brush and vacum cleaner try to clean the grinding entry and gringing burrs. If
this not help then you need to revove top cover panel and so you can clean grindr more closer, check also the burrs they might need to be replaced.
Posted on Sep 04, 2010
I accidentally put water in the grinder will it dry out
no,will not dry .You have to take off the beans canister and get out the grinder knife to clean it.
Jul 11, 2014 | Saeco Magic Comfort Plus Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
Grinder not working
Hi, I had this same problem. Call Saeco and they will e-mail you detailed instructions on how to clean the grinder (2 page pdf file). The directions were great and it fixed our machine. Ours kept telling us to add beans, and the grinder continued to spin. It wouldn't load the beans into the grinder. once we cleaned it (completely) it worked fine.
Dec 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
The coffee grinder on my Magic Comfort Plus is not grinding the coffee. The grinder is spinning but not grinding the beans
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Jan 25, 2010 | Saeco Magic Comfort Plus Espresso Machine
My machine drinds coffee in large pieces.It doesnt grind when I set the regulator on 6 or 7 and appears message "Coffee beans is empty"
HI
One possible problem is your grinder has become separated, so your beans are not feeding equally. The beans are going to one side of the burrs and are ground into big chunks. If you remove the beans in the bean hopper and look down on the grinder. If the cork screw is off to one side that is your problem. Of you can move the cork screw from side to side you need to replace your grinder in either case.
Oct 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
505 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
