Question about Kitchen Ranges
Looking for installation manual for a Viking VGIC3064BSS gas range
4 Suggested Answers
  • 4 Answers
SOURCE: Viking gas burners are too hot
Yes you can but Im not qualified to tell you properly. Our gas guy came over with a long bladed slot screwdriver and lowered ours. IT CAN BE DONE!
Posted on Sep 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Viking Range Oven door will
Viking duel fuel service manual
See page 38
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 17, 2010
aquaman987
  • 927 Answers
SOURCE: I have a 30" viking designer range and am getting
I would be very careful in any situation where you smell gas. Do not use this range until you can be sure that unburned gas is not building up in the area.
How old is this range?
It sounds like when a burner is on, although there is gas burning, there may be some escaping unburned at or around the operating burner or burners.
Posted on Jan 08, 2011
Viking range burners not getting gas
Each burner has to have verification of ignition from the spark ignitor. If all burners will not light I would say it must be the control. Here is your Viking stove manual
Nov 20, 2012 | Viking VGIC485-6G Gas Kitchen Range
We are in need of a Tech Manual for a VGRT5364G conversion from LP to Nat. Gas. Thanks
Manual exist in the location: http://www.retrevo.com/support/Viking-Range-VGRT536-4G-Ranges-manual/id/23666dj391/t/2/
It clearly mentions that:
"A certified
technician is required for any adjustments or conversions to Natural or LP gas."
So pls dont' try unless you already know (and it seems that you don't)
Safety comes 1st!
Jul 28, 2011 | Viking VGRT5364G Cooktop
How do I replace a broken stem on the griddle knob of a forty-eight inch Viking range?
You would remove all of the knobs and then you remove the screws holding the face panel on there. Then you can access burner valves. The new part may not come with a preset orifice because the factory does not know which type of gas you have. So what they do is tighten the orifice all the way down. Lets see if I have a viking service manual:
Viking Stove Manual
Viking parts outlet
Oct 29, 2010 | Viking Kitchen Ranges
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Jul 04, 2009 | Viking VGSC306-4B Gas Kitchen Range
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
104 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
