Question about Clarke Power Products Clarke 16-Speed Drill Press with Laser Centering Device # BT102
Where would I get a new chuck guard for my Model BT1029-16 speed drill press. The part number is DD16108001 and is orange plastic. The press was purchased at Lordo in BC Canada.
5 Suggested Answers
  • 2976 Answers
SOURCE: hi, I have a Clarke Drill Press Model No:- CDP 12HBN
You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
Posted on Nov 24, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a Clarke BT 1001A and need a new chuck. The
you should be able to look in the phone book under tools repair find one locally, on the chuck you have it should give you some number like 33BA or 2 Jacobs, you will need this information to make sure that you get the right one, I would try and find a Jacobs chuck for this, they make the better ones, I have used them as replacements for 26 years and the companies that I worked for prefer them. Let me know if you have trouble finding one and I would need that information also.
Posted on Feb 15, 2010
kel1guy2002
  • 3740 Answers
SOURCE: We are looking for the
You don't have a lot of options. The manual is not listed here:
http://www.clarkeservice.co.uk/product_manuals/metalworking_drill_presses.shtml
(Clarke International.... there is not any other manufacturer website)
Try contacting Clarke here:
http://www.clarkeservice.co.uk/contact_clarke.shtml and request an owner's manual / users guide.
I searched every retailer that had the product listed for a downloadable manual. (no joy after 90 mins)
If you purchased it locally and there is another CLA-BT1029 model around I would ask for a copy of the manual. I understand now why you came to FixYa for help. The manual just is not out there in .pdf format.
Kelly
Posted on Aug 31, 2011
rowdy45176
  • 2176 Answers
SOURCE: WHEN DRILLING UNDER LOAD, THE
it needs to be reseated and to do that you will need to clean the shaft and the internal portion of the chuck with something like brake clean and use a paper towel to wipe off the residue, then move the table out of the way and get a block of wood and hammer, retract the jaws fully and position the chuck and put the block of wood under it and strike it with a hammer a couple times this should take care of your problem
Posted on Sep 02, 2011
How do I make the spindle chuck stay in the quill of my model FDM 16 SPC drill press? I have forced it down on a block of wood. It will stay for a while that fall out.
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
this picture says its a spindle chuck
26313356-3kt1rk2qq1yye1uaamrjudob-5-0.jpg morse taper
Oct 16, 2016 | Drills
How do I remove the chuck from my drill press
Need to know what make and model drill press you have. You could have a taper or a threaded chuck setup. If threaded it would turn opposite drilling rotation and the may be a screw inside the chuck that needs to be loosened/removed and if it is a taper you need a removal tool to pop it out with.
Sep 21, 2014 | Drills
I have a Guardina Power 5 speed heavy duty drill press, model number DP-MINI 1/2 inch chuck. The chuck will not stay on the spindle. There doesn't seem to be any set screw, threads or any type of method...
The chuck is held in by the tapered shaft and friction. Make sure the tapered shaft on the chuck is clean with no burrs. Do the same for the socket side in the spindle. Swing the table out of the way and set a wood block under the chuck. Bring the spindle/chuck down into the block quite firmly which should lock the two tapered parts together. Hope this helps as it worked on my drill press!
Nov 19, 2010 | Garden
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
I have a Clarke BT 1001A and need a new chuck. The original never worked properly. Kept jamming. Where can I get a new chuck. 1/2 inch. The drill press is great.
Feb 07, 2010 | Clarke Power Products Clarke 16-Speed...
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
Hi, I have a Clarke Drill Press Model No:- CDP 12HBN
Nov 24, 2009 | Clarke Power Products Clarke 16-Speed...
I have lost the chuck key where can I get a new
Go to your Ace hardware store ... if they dont have one on the shelf, they can order any size you need. Go with the make, model etc of your drill.
Let me know if this helps you
a
Sep 21, 2009 | Clarke Power Products Clarke 16-Speed...
PRO- TECH DRILL PRESS BENCH MODEL
parts can be found on amazon, take a look here: Amazon com Drill Press parts. I hope this was helpful. Cheers
Jul 19, 2009 | Delta 15 331 15" 115/230V Variable Speed...
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Clarke Power Products Clarke  16-Speed Drill Press with Laser Centering Device # BT102 Logo
160 people viewed this question
Top Clarke Power Products Drills Experts
Are you a Clarke Power Products Drill Expert? Answer questions, earn points and help others
