Question about Konica Minolta magicolor 2430 DL Laser Printer
Help please Fuser Problem?
When i print the image comes partial some parts of the image print some don't and the ink comes off from the paper help
  • MomCarol May 20, 2008
    I have a similar problem. In addition, I get shadows on the page. The same print comes out on of the page very lightly. Also, lots of smudging. I have this problem when I do labels and envelopes as well. I recently replaced the fuser and I though that I wouldn't have the problem anymore, but still do - not always. It's been very frustrating
    I realized I didn't replace the fuser. I replaced the drum.
  • 300 Answers
I'm sure you already know the answer to this, the fuser isn't getting hot enough - either the bulb or a thermistor is faulty.
Posted on May 17, 2008
Why does my 6280 separate one image into two and print it?
Poor fusing of the toner onto the paper is caused by
1. Poor quality compatible/remanufactured toner cartridges that have the wrong toner in them. - Use OEM, or better quality independent toners (and complain to your current supplier about the ones you have)
2. Damp media - high moisture content in the paper prevents correct fusing. You'll probably see the paper 'steaming' as it comes out if this is the case. - Keep your paper dry, only load as much as you need.
3. Thicker than normal media. The thicker the paper, the longer/more heat it takes to fuse the toner. - Make sure you have the correct paper type set in the printer driver at print time.
4. Faulty fuser. Normally the printer will report if the fuser is not reaching the correct temperature, but there are instances when this does not happen. Also it is possible for the fuser heat lamp to blacken partially, resulting in an area of the fuser that does not reach the correct temperature. This problem will affect an area of the page which consistently (same place, and all the way down the page) shows poor fusing. - Replace the fuser.
May 18, 2014 | Xerox Phaser 6280N Color Laser Printer
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
I have a problem of when printing out that is only white paper that take it out even I changed new toner and no change . Pls u have any solution give me the solution .
For a laser printer, printing is a few steps:
* receiving the print-data (which seems to be working fine)
* putting an electrostatic charge on the drum, by using a laser to draw the print-image onto the drum (working?)
* forcing toner into contact with the drum, but only the "charged" part of the drum holds the ink (working?)
* using heat from the fuser-unit to "melt" the toner into the paper (working?)
* ejecting the paper
If the paper is warm, then the fuser is working.
If not, then your fuser needs replacing.
Either take the printer to a qualified printer technician, for professional trouble-shooting, or buy a replacement printer, and responsibly recycle the old printer.
Jul 07, 2010 | Office Equipment & Supplies
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
My printer produces banding on the left hand side of the paper when printing. It is as though stripes of black toner are not applied during the print and it creates the appearance of white stripes. I have...
It sounds like a few things could have happened.. Someone might have put a tyvek type paper in the machine that has partially fused to the FUSER. Or your Fuser is reaching the end of it useful life.
The Fuser is what puts the image/text on the paper.
Replacement of the fuser unit will correct this. The average price for a unit is 175-225 dollars + install.
Apr 02, 2010 | Ricoh Aficio CL3500N Laser Printer
When i use Hp Laserjet P1007 to print, on my page occur repeat the words of overlap and Blur with ink on paper. please help me solve this problem ->contact me at email address:levinh2585@yahoo.com...
You either have a bad toner cartridge or have a problem with the fusing assembly. If it's the fuser will need to have the fuser replaced.
Here's how to tell which it is. Measure the distance from the original image to the first time it repeats on the page.
30.8mm (1.21") = toner cartridge
76.3mm (3.0") = toner cartridge
41.0mm (1.61") = fuser
56.5mm (2.22") = fuser
Hope that helps you. :)
Nov 15, 2009 | HP LASERJET P1005 Printer
Ink toner problem?
No, that is not the ink, That is a fuser problem.
The fuser needs to be replaced.
It is a very easy repacement. Cost is between 170-200 dollars if you don't have a service agreement.
One of the two rollers in the fuser has a problem and is not making good enough contact to fuse the image.
Jan 10, 2008 | Xerox WorkCentre M15i Laser Printer
Ink not sticking to paper on textweight, possible fuser problem?
Have you properly make setting for media attributes ? plain -normal paper.
Nov 05, 2007 | Xerox DocuColor 12 Printer
Printed image
There is no temperature setting for the fuser unit. Either your paper is too humid (it also curls when coming out of the unit). Or your fuser unit is bad.
Jan 23, 2007 | Xerox WorkCentre M15i Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
109 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
