Question about Whirlpool Refrigerators
Ice maker does not make ice, 5 year side by side
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 03, 2010
Problem with my chocolate side. Will not remain as firm ice cream. Becomes liquid ice milk. I turn chocolate side off. After I turn back on it may still be liquid but not firm ice cream.what can I do?
Homemade Ice Cream Mistakes-and How to Avoid Them ...
www.bonappetit.com/test.../common-ice-cream-mistakes
Bon App?titJul 30, 2014 - Ice cream machines are easily found and affordable, so procuring the ...Once ice cream is properly chilled, it should be firm but not a solid, ...
5 Mistakes to Avoid When Making Ice Cream - Cooking ...
www.thekitchn.com/5-mistakes-to-avoi...
Apartment Therapy's The KitchnJul 20, 2015 - Not letting the ice cream maker bowl get cold enough. ... churning away in the machine, this process doesn't end with the firm, super scoopable ...
Will a new ice cream maker make my ice cream set firmer ...
www.chowhound.com/.../ice-cream-maker-ice-cream-set-firmer-964328
Feb 12, 2014 - I've been making ice cream at home for a few years now and tend to have pretty mixed results with how firm my ice cream gets. Even with all ...
Jan 10, 2016 | Ice Cream Makers
Kitchen aid icemaker won't dump
Sounds to me that you need parts or as most Whirlpool/Kitchenais Ice Makers their averagte life is 5 years. Call before purchace to confirm but here is what I have for the complete Ice Maker=> 4317943 Ice Maker Assembly
For much more info click here=> Broken Ice Maker Repair
I will be here if you have any other questions, Thanks, Sea Breeze
utube.png You-Tube video "VCUgA5T5ASw&feature=player_embedded#!" placeholder
Sep 18, 2011 | KitchenAid KSCS25FKSS Side by Side...
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Ice maker problem
Here are some basic tips for ice maker troubleshooting2_bing.gif...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
Gss20I eph ice maker ?? If I turn the switch of
I am almost sure the model ice maker for your refrigerator is Click Here=> WR30X10093 and the model number for your refrigerator is GSS20IEPHWW or SS for Stainless. It sounds as if a bad connection on the ice fill arm. The truth is they are electronic and made in China along with most of the parts on your GE. I replaced mine that was the mechanical type with this same model number WR30X10093 and the mechanical lasted 15 years. If you manually can make it work one time and fills properly but after one cycle yet turns itself off my focus is on the ice maker. If you want to check OHM's to the dual water control valves they should both be about the same. Applying 120 volts to each side of the coils being water dispenser side and ice maker side will or should open them. But you just said that moving the arm that it will fill one time so I am back to the ice maker again. If water control valve for ice maker side did not work you would not be able to do that. Sea Breeze
May 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker stoped
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have a side by side refrigerator that is 5 years old, and the ice maker does not work. We purchased a 5 year warrenty from Best Buy and requested warrenty repair. It took 3 weeks to get the repair part...
The ice makers are rather finiky. limit switches for almost every movement. Sounds excessive, but replacing the ice maker module will save you a lot of worries. The signal to fill with water comes from the icemaker when it is in the correct position
Sep 14, 2009 | Refrigerators
Ice maker has ice in lower back part of ice maker, rotation stopd
you say ice in back of ice maker??? only the rear 2-3 cubes are filled??? adn the front 5 or so are empty??? then yes its possible low water pressure from a faulty filter can be an issue, shoudl be replaced at least every year. so you cant go wrong by changing it , at least rule it out!
Nov 22, 2008 | Frigidaire FRS26R4A Side by Side...
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
