My whirlpool calypso has a code ca - Washing Machines
  • 6,784 Answers
HI. This is a basic over current event that has occurred in the motor circuit and corresponding devices that are locally mounted on and near the actual motor assembly. The components near the motor assembly will be the Motor Controller and Thermal protector(mounted on he motor). If a status signal comes back from the motor controller Indicating that a current limit has been breached, the unit will return to standby mode and display either “CA” for average current limit trip or “CI” for instantaneous current limit trip.
An average current trip occurs if there is a two second average of current draw greater than 5.55 Amps at the motor windings. This may Indicate that there are problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem as well and induce the CA or CI code.
The necessary actions are to run a automatic diagnostic test to isolate the problem area. The unit must be empty when starting the test. The automatic diagnostic mode will enable activation of specific machine functions without having to run a cycle. Each function test will time out in three minutes prior to initiating the next test. It is totally automatic when started. I will provide the service manual for your unit. The actual automatic diagnostic test procedure will be described on page 48 of the manual i have provided below. Simply clikc the linke below to access the manual. It will take up to 4 minutes to download the manual to your browser. Once it is fully downloaded,promptly, scroll to page 48 to begin the automatic diagnostic testing procedure.
Whirlpool Calypso Service Manual
Please report the results of the test so that I may complete my solution.
Standing By....
Posted on Sep 03, 2010
  • Michael Masters
    Michael Masters Sep 03, 2010
    • Press STOP/CANCEL to clear the display before starting the Auto diagnostic test..
  • 10,865 Answers
Hello. The CA code means that the average current draw at the motor winding has exceeded 5.55 amps for more than two seconds. This could mean a problem with the drive motor, the thermal protector, or the motor controller board. Overloading the washer can also cause this fault. Page 57 of the service manual gives specific tests for the drive motor and wiring harness. Start there. Here is a free link to that manual https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Posted on Sep 08, 2010
4 Suggested Answers
  • 351 Answers
SOURCE: CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
Posted on May 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite calypro CA error code. Plus makes
The CA indicates that an average current limit on the drive motor has been exceeded (see images below). This is an extremely hard problem to diagnose and one that I've seen cause the best service techs to pull their hair out. It can be one of so many different components, and you have to catch conditions just right to have half a chance to discover which one it is.
Try removing some of the clothes; this could be caused by overloading. You could have a mechanical failure in the universal joint, wiring harness, the drive motor, central control, or the motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code c1 of ca
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Posted on Sep 23, 2010
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
What does C.A display mean on whirlpool calypso washer ???
C-A means average current limit trip or an overcurrent of 5.55 amps on the motor w2indings which means there can be issues with the motor controller,thermal protector,or the drive motor itself,press stop/cancel to clear the code,then try running smaller wash loads as to large a load can trigger this condition
Nov 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CA on calypso
http://www.applianceaid.com/calypso-codes.html#wash
Sep 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washing Machine "Cl or Ca"
The control board is reading too high of an amp draw from the motor,Most likely a bad drive motor.
Sep 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Have code CA
yep overloaded remove some clothes and consult owners manual for proper load select stop/cancel to clear code if that doesnt work unplug unit for 1 min
Jan 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
