Question about SSI America Neo Car Jukebox 40GB MP3 Player
Was using it in the car and it stopped playing. Turned it off and on again and it played for a while and stopped playing again. Turned it off and back on and it would error out during boot. Tried that a few times and smelled a burnt smell. Turned it off. Removed it from the car dock and put it in the house dock and plugged it into the computer via USB and am not moving the files off of it. What do you supposed went bad on the car dock?
Why am I"m getting the message Unfortunately the process android.process.acorehas stopped
may be yo pone is not supporting all those games... so must check the compatiblity before instaling the games.
Aug 09, 2014 | Samsung Galaxy S 4G Cell Phone
What does repeat mean on my mp3 player?
It means that your selected song/item is on repeat. It will keep playing again and again.
May 25, 2011 | Gomadic Classic Straight USB Cable for the...
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
My xbox 360 freezes when playing online
The G.P.U is starting to desolder from the
main board . The fix is an X clamp Mod
100% solid fix, no kiding.
more info
www.all-xboxrepair.com
Mar 17, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Stopped playing music
Since you have a MAC, your probably using ITUNES, ITUNES are MP4 format which this unit doesnt play, you have to make sure what your putting on is MP3 audio files:
Here is a guide on how to convert songs to MP3 on ITUNES:
http://www.wellesley.edu/Computing/Idocs/Itunes/convertMP3.html
Once you get the audio files converted, drag and drop on the drive from where they are saved on your computer.
To play the audio files:
hold the play button until red light comes on, then press Play again, light should blink which means its playing.
Jul 31, 2008 | Coby MP-C883 MP3 Player
System stops playing
Hi Big Belchie
Sounds a bit like it is overheating. It is in a cabinet? Check that cooling vents on top and sides of the unit are not getting obstructed. hehehe sometimes parties are responsible for those piles of cd covers that block off the vents. How hot does it feel when it stops working?
regards
Graeme
Apr 12, 2008 | Technics SC-DV290 System
CANT FIND MY SONGS ON MY RCA MP3 202C
you have to hit the play button again. When it turns on it it automatically turned on the "stop" setting. hit play again to get it going
Jan 20, 2008 | Delstar DS 31024 MP3 Player
Sony NW-E105 doesnt turn on!
Yes, I also suffered from the some problem. Have any solution
Oct 09, 2007 | Sony Network Walkman NW-E105
SSI America Neo Car Jukebox 40GB MP3 Player Logo
63 people viewed this question
Top SSI America Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SSI America Audio Player and Recorder Expert? Answer questions, earn points and help others
