Question about Acer Aspire 5610-4648 Notebook
How to replace dvd drive acer aspire 5740G - Acer Aspire 5610-4648 Notebook
SOURCE: How to replace the DVD drive on Acer Aspire 5002
I actually had to permorm this action yesterday.
First remove the small strip above the keyboard by unscrewing the three screws at the back of the machine that hold it; then twisting the screen al the way back and lifting it up.
Second unscrew the keyboard (2 screws) and lift it away (don't detach the cable).
Third: on the left side under the keyboard unscrew 3 screws that hold the cdrom in place.
Pull the drive out. The rest (taking the case of the dirve) should be transparent.
There is nothing on the bottom you have to unscrew!
anthon@mnt.org
Posted on Nov 05, 2009
Pyrhyc
  • 2028 Answers
SOURCE: acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
Posted on Aug 30, 2008
  • 389 Answers
SOURCE: How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Posted on Jan 24, 2010
SOURCE: Acer aspire 5735z - how do you remove the dvd drive?
Found the answer! There is a screw underneath. Second screw up from the bottom edge of the computer (near the dvd drive). Undo this and the drive pulls out. Hope this helps someone else.
Posted on Feb 02, 2010
  • 2386 Answers
SOURCE: how to reomve a faulty CD/DVD drive from the Acer
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Posted on Jan 10, 2011
Acer aspire 5740G turns off after 6 seconds
Does it do it when connected to a working charger?
Jun 25, 2014 | Acer Aspire 3680 Laptop
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
I HAVE THE LAPTOP ACER ASPIRE 5740G. I WANT TO FORMAT THE HARD DISC AND FIND THE DRIVERS FOR WINDOWS XP
You can format the hard drive using the Windows XP CD
  • Download the drivers from the Acer website and burn them to a CD or DVD
  • Make sure that the CD drive is the first drive to boot in the computer's BIOS
  • Press a key when the CD starts to boot
  • On the blue screen press Enter
  • Press F8 to agree to the license
  • Press Esc for a new copy of Windows
  • Press D to delete the partition on the drive
  • You may need to press Enter and L to confirm
  • Press enter to install Windows
  • Choose the appropriate format option
  • Windows will install
  • Insert your driver CD or DVD and install the drivers.
Jul 24, 2011 | Computers & Internet
Laptop acer aspire 5740g. No light indication when i connect ac adapter and no response when i press the power button totaly dead.What is the problem
My laptop been droped.
Dec 16, 2010 | Acer Computers & Internet
I bought an acer aspire 5740G from abu dhabi on 29/06/2010.i have 6 months warranty.but i want to avail 1 year warranty
Contact Acer on their WEB site to see if you can increase your warranty period. There is usually a charge to extend the warranty period.
How to use p button for acer aspire 5740g laptop
"P" button can be associated with whatever program you like. To make it work, download Acer launch Manager from
Acer Launch Manager LINK1 or LINK2
Have a Nice day :)
Nov 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
My computer is a Aspire 5740G then i downloaded this program called magic-i visual effects and then when i tried opening the acer crystal eye webcam it didnt work and then i uninstalled the program magic i...
the program may caused your camera driver to be corrupted.. try reinstalling the camera driver..
http://www.acersupport.com/drivers_download.aspx
just select your computer model and it wil give you the lost of drivers for your computer.
Sep 08, 2010 | Acer Aspire 5610-4648 Notebook
Dvd drive removal
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
go here and look on the site for some goood tips and pictures
I hope this helps
Dec 24, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
415 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
