Question about Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5)
I just bought a dynex ethernet switch so that my daughter can plug her laptop into it and access the internet. I have a dsl modem connected to the switch. i have the switch connected to my desktop. I can access the internet fine on the desktop. I have the laptop connected to the switch, but it will not access the internet. I've tried different ports and different cables.
  • Dynex Master
  • 27,725 Answers
Maybe you need to configure this ethernet switch or it is a password problem i have used a ethernet splitter switch to use two connect 2 computers before purchasing a router which needed to be configured
hope this helps
Posted on Sep 03, 2010
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Do I need Wi-Fi to get on the internet on my Acer E-Machines E725/E525 Notebook Laptop Computer. I bought a wireless router and a wireless USB and neither one of them or working even when I put the CD's in...
IF you do NOT have DSL, "but I do not have DSL" (sic) then you must connect up to the internet, via a MODEM, the phone line connects to the Modem, the MODEM connects to the PC via Ethernet cable. Then you use the Connect to internet Wizard. You will need to enter your login and password, for your ISP, so you will be able to access the internet. You also must enter the ISP's PHONE Number to Dial up, FIRST, then you must enter your login, and password. Then you will connect up to your ISP, and be able to go onto the internet through them. That's it, really.
May 13, 2010 | Computers & Internet
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Dynex dx-ehb4 will not change ip addresses
I am not familiar with that router so I will provide general knowledge and you can apply it to fix your problem.
It sounds like your cable modem is willing to supply a single IP address. This can and should be connected to the WAN port of your router. The problem is that the router is not assigning IP addresses to the equipment that is connected to its LAN ports. Instead, it allows that single cable modem IP to be assigned to connection #1 and everybody else gets nothing. Get the computer working through it, connect to the router as per the owners manual and turn on NAT or DHCP, whichever it offers. Reboot the computer and connect xbox and you should be good. This was probably not an issue with DSL because your DSL modem would supply up to about 10 IP addresses and they also passed through the router.
Mar 03, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5) Logo
220 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
