Question about HP 35s Scientific Calculator
MY NEW 35S TURNS ON TO RPN----HEX DISPLAY SHOWS 0h 0h HOW DO I GET OUT OF THIS MODE?
Blue shift and base (1)
Posted on Sep 13, 2010
HP 35s in OCT mode, calculations don't work
There are two separate issues here.
Your calculator is in Algebraic mode. To switch to RPN, press MODE 5 .
Your calculator is also in Octal mode. To switch to Decimal, press right-shift 1 1 .
Mar 24, 2014 | HP 35s Scientific Calculator
How to but the calculator in enginering mode
Press left-shift DISPLAY 3 then a digit for the number of desired digits.
Mar 06, 2014 | HP 35s Scientific Calculator
How to remove RAD from HP35s
Press MODE then 1, 2, or 3 to select the desired angular mode. In any mode other than degrees the display will indicate the mode.
Mar 13, 2013 | HP 35s Scientific Calculator
I'm in RPN mode, how do I get out of RPN mode?
To switch to the algebraic mode press f [ALG] (the EEX key).
Dec 08, 2011 | HP 12c Calculator
AIG function is on and I can't get it off
If you mean "ALG" then your calculator is set to algebraic notation. To switch to RPN, press MODE then 5.
Feb 17, 2011 | HP 35s Scientific Calculator
Hp 35s...hex display showes 0h 0h cant change out of this mode
Press right-shift [BASE] 1 to select decimal. [BASE] is the blue-shifted function of the 1 key.
Sep 13, 2010 | HP 35s Scientific Calculator
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
Programing using if then statements
HP's RPN calculators have always followed the "do if true" rule. If the test is true, the next step is executed. If false, the next step is skipped. So, in your case, you would simply follow the x>y instruction with the goto instruction. If the test is true, execution will brance to the specified label. If false, execution will continue with the step following the goto.
Apr 02, 2009 | HP 35s Scientific Calculator
HP 35s Scientific Calculator Logo
285 people viewed this question
Seeker5211
Seeker5211
