Question about Dryers
Motor pulley broken in half.... Cannot get the half that remained off to replace it. How can we tread this thing off of here??? Maytag Dryer.
    President:
  • 3,074 Answers
You can either cut it off or try using a pulley
Posted on Sep 03, 2010
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Kenmore 110.731102100 Gas Dryer replace belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Kenmore Dryers
How to replace a belt on a dryer
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
I'm looking for a dryer motor pulley for my maytag gas dryer model # PDGT910AWW. the belt broke and when i went to change it the pulley was split in half. i was told that the pulley only comes w/ the...
unfortunitly you have to buy the motor to get the pulley,i just tried to get one for you through the repair clinic but no dice,you can try home depot or sears or any other place that you know of that sells appliances,when they deliver a new dryer they take away the old dryer so you might get lucky and find a condemed dryer with your pulley in it or install a new motor.good luck
Feb 22, 2011 | Dryers
How do you replace the belt on a Maytag clothes dryer
frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
Apr 24, 2010 | Dryers
Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Apr 09, 2010 | Maytag Dryers
The dryer on my maytag stacked combo lse7804ace the motor works but the dryer doesnt spin. Broken belt?
You will need to either re-install the belt or replace it. I would assume that it's broken because it's not that common for it to just run off the pulleys.
Oct 19, 2009 | Maytag LSE7806A Top Load Stacked...
I replaced the idler pulley and pulley arm on my Maytag Dryer model#SDG2606AWW, and now I don't have enough tension for the drum to turn.
http://www.pcappliancerepair.com/model-display.php This site shows your belt going around the motor a half turn, grooves to the pulley. Then you have to wind up the spring-pulley and put the belt over the roller a half turn. That should take up the slack. The packaging of a new belt should show how it goes.
May 12, 2009 | Maytag Dryers
Pulley broke
i am instructing on the motor pulley.it is plastic,get it off any way you can with out hurting the motor shaft.i think somtimes i would use large channel locks.you dont need to save any of it.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Nov 22, 2008 | Maytag MED5770TQ Electric Commercial Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
