Question about Zebra Z4Mplus Label Printer
I would like to load font setting from Z4M Plus printer. It is not just "List Fonts" but load such as font size, position, format, and etc.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Try using a label design software.
Posted on Oct 12, 2010
Outlook 2003 on XP. Received mails appear in HTML in very small type. How can I change the type size?
To set the default HTML font:
  1. In Internet Explorer, choose Tools ' Internet Options.
  2. Click the Fonts button.
  3. On the Web page font list, select the font you want to use as your default.
  4. Click OK to return to Internet Explorer. Note that this change affects web pages, not just HTML mail messages.
http://www.slipstick.com/mail1/changefont.htm
Mar 06, 2011 | Microsoft Computers & Internet
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
MY HEWLETT PACKARD DESKJET 3520 PRINTS IN SUCH SMALL FONTS ITS VERY HARD TO READ.HOW DO I CHANGE THE FONT SIZE TO A NORMAL BOOK SIZE FONT?
Change the font in the application that you are using.
The problem may be that the printer's resident fonts does not include the font you are calling. So the printer's logic says, "Go find the best font you can." The font search gives you the wrong font.
If your printer allows you to print out the fonts, do that and make sure the font you want is in the list.
If it is not, then you will have to use a "Soft font" and make sure that your application knows to download/include soft fonts to the printer
Don
Feb 15, 2010 | Office Equipment & Supplies
No ip info on menu
There is a tiny button on the print server back plane that you can press with a paper clip. This will print out a label with your IP address information. Get the IP address (hope that the printer is set for DHCP) and enter this into a web browser. This will take you to a web interface that will let you make configuration changes to the print server and printer. If the printer is set to static IP, change the IP address of your PC to be in the same subnet as the printer and then fire up the browser.
The user name for the printer is ADMIN and the password is 1234 by default. You can also download ZebraNet Bridge from Zebra's web site. This application will find your printer on the network and let you install fonts, upgrade firmware, change settings, etc.
Jan 19, 2010 | Zebra Z4M Printer
I want to know how to increase the size of my fonts on my printer . where the computers fonts are large enough when I print out aany thing it is small I have a lexmart x 5070
iterry,
The font size is controlled by the application, whether it be MS Word, Excel, or whatever.
If it is Microsoft Word, then:
1. Open a document
2. Select [Select All] from the [Edit] menu option
3. All text is now highlighted.
4. [Format] [Font]
5. Select the font Size, etc.
6. Print it out.
You may not want to "save" this document.
Do the same for other documents, etc.
Nov 09, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Using multiple printers on switch box. Z4M Plus and Z6M. Sometimes data is missing or printed incorrectly. Font size changes or certain text is missing. We are using Label Vision Version 4.3. It is like we...
The problem with this type of printer is that when you use true type fonts, they are downloaded as graphics. If you have a field which changes on each label there is an overflow of memory. The solution is to use internal fonts for continuously changing datas
Oct 08, 2009 | Zebra Z4Mplus Label Printer
I need to know what the difference is between a Z4m and a Z4m Plus.
Mechanically there isn't much difference. Electronically the 4Mplus replaced the 4M giving it more memory, ZPLII capabilities, and the ability to work with new barcodes and fonts that weren't supported by the 4M firmware.
May 14, 2009 | Zebra Z4M Printer
Unable to load post script fonts in windows-xp
Well postscript fonts are vector outline fonts, so they contain instructions about the building of their outlines and curves and such. Hence two files are required to use a postscript font under Windows.
As to how to install these fonts, well
  1. Click Start | Settings | Control Panel.
  2. Double-click on the Fonts folder.
  3. Choose File | Install New Font.
  4. In the Folders menu, navigate to the folder containing the fonts that you wish to install. A list of available fonts will appear in the List of Fonts window.
  5. Click on the font you wish to install or use the "Select All" button to install all fonts in the List of Fonts.
  6. Click on OK.
Please keep in mind:
  1. If you are installing fonts from a CD be sure the 'Add without copying files' box is NOT checked; unless the fonts are on a located somewhere (such as a network) which you will have access to at all times.
  2. Postscript fonts have two files: PFB (printer font binary has outlines that control how the font looks) and PFM (printer font metrics has information about font spacing). Be sure you have both font files.
  3. If you currently have or previously had Adobe Type Manager Deluxe 4.0, 4.1, or 4.1.1 installed you may need the Adobe Deluxe Updater in order to properly use your Postscript fonts under Windows XP. Get it from Adobe.
Hope this helped. Let me know and if yes please rate me:)
Feb 15, 2009 | Adobe Computers & Internet
Zebra zm400
connect the printer to a desktop or laptop using LPT1.
Jul 10, 2008 | Zebra 203DPI Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Zebra Z4Mplus Label Printer Logo
301 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
