Question about Lexmark X5495 Printer
I'm trying to print & scan some papers for school & printer is not working properly, it says that theres an alignment problem & to remove tape from cartilage & then to check paper & retry again. What I don't understand is REMOVE TAPE FROM CARTILAGE.....WHAT DOES THAT MEAN & HOW DO I DO THAT????
    President:
  • 2,571 Answers
When you install a new ink cartridge, it has a strip of tape on the top, you rip this off and install the cartridge. Then go to the printer preferences and in the tools menu there will be an alignment tool
Posted on Sep 03, 2010
Dont scan the sheet after align cartridges
You mean align page not scanning/not completed?.if align page not printed properly due clogged nozzles, printer unable to completes align successfully, remove both cartridges clean nozzles as shown in attached link, refix & try, even not resolved replace faulty cartridge, or else when its performing the align printing cancel it,but every time when switch on the machine it will print align page..http://www.youtube.com/watch?v=0nWCTKPaBlo
Oct 06, 2011 | HP J3680 Officejet All In One Printer
I have HP 3180 all in one. Stopped printing. Flashed paper and ink lights so changed ink and loaded paper. It spit and spat and sent out blank pages. Now, no matter what I try to print, in any and every...
Hi
Nice to know that you have enough knowledge to do the basic techniques required.
Anyways Did you try to align the cartridges? first time when the cartridges are installed the printer prints the alignment page which needs to be scanned by the printer, did you perform this set? if not then try to goto tools menu in your printer and try to use the option align cartridges. Only then the cartridges will be aligned and calibrated to print.
Jul 16, 2011 | Office Equipment & Supplies
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Alignment problems and color is not printing the color I want
Hello. Try to resolve the alignment problem first. That might resolve the print quality too. Here are some tips on what you can do to resolve the problem. Remove the cartridges from the printer. Close the cover of the printer without the cartridges. Unplug the printer from the power outlet. Leave it unplugged for now. Take a warm, damp paper towel. Set one ink cartridge on the paper towel like how it is placed in the printer - nozzles facing down. Drag the cartridge lightly across the paper towel in one direction (left to right) until the bottom of the cartridge looks clean. Do the same thing to the other cartridge. Plug the printer to power source. When printer asks for the cartridges, load them back in and properly secure them in its place. Close the cover. The printer may print an alignment page, just let it be. Hope this resolves your problem. Good luck!
Mar 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Need 2 calibrate my hp 1210 printer
Hi *s*
(bottom left corner windows START)
got to;
start/settings/printers/ and click
right click your printer and select printing preferences
click on the tab that says SERVICES
then click on the services icon button (picture)
you will see three choices;
align,
clean
print a test page.
Aligning is what you want.(calibration is just a different word)
You can also remove the ink cartridges as you usually do and then put them back in, this triggers and automatic printed page and then walks you through scanning and the alignment.*s*
if by chance you still have blurry printing and know your machine should be ok, try cleaning.( same procedure, different last choice- you clean the heads)
You can also check to see if the proper paper is selected. For instance, if you are trying to print heavy greeting card paper it must be set to that or it will not print properly. *s*
If you have thrown up your hands and tried all this, and nothing works. Go through your printer preferences and select SET DEFAULT SETTINGS buttons.
It will knock everything back to the way it left the factory *S*
Thank you and good luck. Please remember to give my answer a rating *S*
Oct 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP 1410 Printing Error
did you try scanning the test page after printing? this usually keeps the printer from reprinting the test page each time it is turned back on. Not sure about the paper jam.
Jun 24, 2008 | HP PSC 1410 All-In-One InkJet Printer
Lexmark X5495 Printer Logo
284 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
