I have an HP pavilion PC which will not stay on even with the adapter. I have replaced with new battery, still doing the same thing..
  • 37 Answers
You need to check th power supply it maybe at fault another option is to remove all extras ie the memory and the hdd sounds daft but if you systematically remove each of them, and try booting the unit it may initalise. if so replace faulty part.
Posted on Sep 03, 2010
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
Diescribe your Pavilion dv7-1245dx PC Notebook. just recently i purchased a new battery and i returned it because it was not charging correctly so i got another one and i,m still having the same problem, i...
It is normal for the adapter to run warm, but it shouldn't feel so hot you can't touch it. Since you have tried a couple of replacement batteries and still have the same trouble, it's safe to assume that either your adapter is bad or that there's something wrong on the computer system board. New adapters are easy to find and not very expensive (here's one seller on eBay), so that would be the next thing to try.
If the motherboard is the trouble (something wrong with the charging circuit), that's replaceable as well but it's not a cheap or simple repair. A replacement board may cost $100 to $200 for a used and tested part, and over $300 for a new one from an HP-authorized part seller, and installing the replacement can be very tedious. It might be more economical to replace the computer if the motherboard is bad. Try a new charger first.
Sep 11, 2011 | HP Pavilion dv7-1245dx Notebook
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has...
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My HP Pavilion 2500 will not start up, the blue light on the computers powerport blinks instead of staying on. I have tried a new power supply and removed the battery several times and replced it.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced
Sep 10, 2010 | HP Pavilion dv2500t Notebook
HP Pavillion zd8000 will not turn on?
1. take out battery
2. plug the unit in without battery
try to boot it like that. If that does not work you might have a bad power adapter or even a burned motherboard. We do not know unless you try these things.
let me know
please do rate this and leave feeedback
Jun 26, 2010 | HP Pavilion zd8000 Notebook
My hdx dragon laptop battery is not recharging, even with a new battery installed no charging is possible.Can you help ?
If your computer functions while plugged into the ac adapter, but the battery still is not charging, then the battery will likely need to be replaced. If your computer does not run while plugged in, then you may have a faulty ac adapter. You should be able to obtain a replacement adapter from the manufacturer or a universal one from a local component shop or online
Apr 14, 2010 | HP Pavilion HDX Laptop
I have a hp g6000 power coes on but screen is
1. If you have it plugged to a power adapter it could be that the AC adapter is not charging the battery.
2. Try removing the battery with the AC adapter plug in and see if the PC will. if so then you may need a new battery.
3. You will need to get new AC adapter and battery frome the manufacturer or authorized dealer. Third party device are not recommended because they usually are not up to specifications.
I hope this helps.
Mar 16, 2010 | HP Pavilion dv6000z Notebook
I noticed that my laptop power stayed at 16% even though I was on power for over two hours
Try to removed your battery and put only the power adapter in your laptop, see if its turns on. IF not, changed your adapter. It may be also your battery which is faulty.
Feb 15, 2010 | HP Pavilion dv6000z Notebook
Tried everythin,
If your laptop is on this list (ck #) you are eligible for extended warranty service.
Mar 28, 2008 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
