Question about Corona 23-DK Compact Heater
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
  • 24 Answers
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Posted on Sep 03, 2010
Black smoke coming kerosene
hi dear,
First of all make sure that the heater is filled with K-1 Kerosene. Other fuel, such as gasoline, home heating oil, etc. do not burn hot, causing the heater to burn out of control. NEVER USE GASOLINE or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 Kerosene. If you are sure of your kerosene and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure your heater is not in a draft. Too much air can create a very high flame condition. Avoid placing the heater in drafty areas or under a ceiling fan. Make sure the burner chimney is seated correctly. If the burner chimney didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be raised too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned, or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact wick height. If the wick is installed correctly and there is no other obvious defect it is best to take the heater to a service center to determine the cause. Our Find a Retailer tool can be used to help find a servicing center.
Jan 04, 2014 | Corona 23-DK Compact Heater
Heater will not stay lit after firing it up. Replaced wick and kerosene.
Two things usually cause the problem you noted. An improperly installed wick or the tails of the wick are not all the way into the tank. Therefore, it won't absorb enough kerosene for it to continually burn
Check out those two things and one of the other should solve your problem.
Feb 03, 2011 | Corona 23-DK Compact Heater
Corona 23-dk heater burns fine when filled up but flames starts going very low a little pass the 1/2 line on fuel gauze. what causing that.
From your description, it sounds like the wick may need replacing or the tails of the wick are not hanging all the way down into the tank. And, therefore they are drying out. Thus, your flame gets low and eventually goes out. The only way to know is take the heater apart. If you're not comfortable doing that check with your local hardware stores, like True Value or Ace. many of these store do repairs on kerosene heaters and replace wicks. It can be a messy job, but someone has to do it.
Jan 21, 2011 | Corona 23-DK Compact Heater
Is it possible to manually ignite a corona 22dk kerosene heater safely with a butane lighter? the battery operated igniter is not working with new batteries installed.
I just use a match. Turn the setting dial to High. Open the little door in front. The one with glass in it. Light the match. Push the pedal down that you normally use to start it with the battery starter. Put the match into the heater and touch it to the wick. With just a regular match, I can reach in far enough to light the wick. When you have a complete ring of fire, lower the pedal slowly and close the door. It will smoke briefly and then burn. After 15 minutes lower the wick till the flame is smaller and whiter.
Sep 13, 2010 | Corona 23-DK Compact Heater
Changed wick in corona 23dk , now has very high flame and smokes like crazy.
the wick is round in this heater and may have to be cut for height. should be about an eigth of an inch below the top
Jan 11, 2010 | Corona 23-DK Compact Heater
12-dk kerosene heater
well other then getting dirty and tearing it apart...... on the dk-12 when you install the new wick the black line needs to match up with the adjusting coller then you push the wick onto the teeth and assemble the hard part on mine is the piece below the wick that guides the wick in the bottom there needs to be a little slack so the wick can get raised and lowered. I hate to sound like I like ace hardware but from where I am at there guy there is great rebuilding these.
Nov 28, 2008 | Corona 23-DK Compact Heater
Kerosene heater
Turn knob all the way to the right. Your wick may not be mounted right. The pins are out of the guiding wholes.
Nov 14, 2008 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
341 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
