Question about Cameras
Got a new SDHC card and the camera keeps saying it needs formated. tried it in a different camera and it works just fine
  • Stephan Reichert
    Stephan Reichert Sep 03, 2010
    What type of camera do you own?
    Brigadier General:
  • 11,967 Answers
New cards need to be formatted in the camera they will be used in to work properly and efficiently.
Posted on Sep 03, 2010
My camera akodak easy share, DX6490 Has 2 sanDisk 128mb that Ibought with the camera in 2003 Works fine. The new sandisk cards 4gb say they need to be formatting. The camera keeps repeating it needs...
If you've tried to format the cards in the camera and it failed, it's probably because the cards are SDHC cards instead of SD. With a camera as old as yours, SDHC cards hadn't come out yet.
Aug 18, 2011 | Cameras
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
Card not initilized? what does this mean?
It means the card has not been formatted, or that the camera doesn't recognise the format, but that might not be the full story. You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
The first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then the card may be incompatible. Formatting deletes anything already on the card.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
If it is a new SD card, then maybe it is actually an SDHC card. "SD" cards larger than about 1GB are usually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible
Jan 22, 2011 | Fuji FinePix A330 Digital Camera
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Kodak EasyShare CX7525 Digital Camera
Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
Dec 25, 2010 | JVC Everio GZ-MC200 Camcorder
I just purchased 2 new sdhc class 6 cards from ebay. I put them into my jvc everio camcorder and it says "memory card error". Do I have to format them, or are they bum cards? Thanks
I doubt there is anything wrong with the cards. Cards usually come pre-formatted, but you could try formatting them and see if it makes a difference.
However, I expect that your problem is down to compatibility. Many cameras, especially those that are a couple of years old, won't work with SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different. SDHC is not backwards compatible. Unless your camera's manual specifically mentions that you can use SDHC cards, you probably can't. I believe the largest capacity SD card is 2GB. Anything bigger will be SDHC.
Dec 24, 2010 | Cameras
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
I have a Kodak Easyshare Z740 & we just purchased an 8gb sdhc SanDisk & it keeps saying it needs to be formatted it says everything will be deleted and then goes back to disk needs to be formatted...
You need to buy an SD card. the Z740 works with SD and MMC cards, not SDHC cards. While SDHC cards will fit into an SD slot, there are hardware differences which keep them from working. SD cards will work in SDHC devices but not the other way around.
Again, you need to use SD cards, which max out at 2GB. Anything larger is an SDHC card, which does not work in your camera.
Apr 26, 2010 | Kodak EasyShare Z740 Digital Camera
Problems with formatting memory card
I'm guessing you're trying to format a new 4GB SDHC card? If so, am sorry to say that your camera was designed before the SDHC format came out. Although it looks exactly the same as a standard SD card, the format the card uses is very different.
You'll need to instead purchase a standard SD card (those that are 2GB or less). Forunately these are very inexpensive these days, with 2GB cards going for around $6 with shipping.
But if you must use 4GB, Transcend makes a 4GB standard SD card, but I can't guarantee that it will work with your camera as anything above 2GB for standard SD may have compliance issues.
Nov 02, 2009 | Cameras
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
