Question about Texas Instruments TI-83 Plus Calculator
How can i draw graph. - Texas Instruments TI-83 Plus Calculator
  • Texas Instru... Master
  • 7,993 Answers
This should help you setup your calculator to do graphing.
1. Prepare calculator for graphing
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
2. Setup Graph type
  • Press [MODE] key.
  • In Mode set up screen, make set the angle unit (if you are drawing trigonometric functions)..
  • Use the arrows to move cursor to 3rd line to highlight degree or radian and press [ENTER]. The important thing is that you be aware of the unit so that you do not get unexpected results.
  • On same screen, verify that Func is highlighted. If you are drawing PARametric plots, POLar plots or SEQuence plots, you highlight the relevant item in the list
  • If it is not, use arrow to highlight Func and press [ENTER] to validate.
  • Do not worry if you do not have exactly the same screen as in the screen picture (We may have different OS Versions)
3. Entering the functions to draw (assuming you want to draw y= functions)
  • Press [Y=] to enter function editor.
  • Type in a function
  • Press [ENTER] at the end of each function.
  • Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  • In the screen capture 4 functions are slated to be drawn.
4. Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
  • Select the graph style: The small piece of line to the left of a Y that defines a function is the style.
  • Move cursor on it and press [ENTER] .
  • Each [ENTER] (on same line) selects another style.
  • On the next screen you have all the styles available on the calculator.
  • Do not select the bubble on line 6: It is for animations. It will not leave a trace at the end of the plot.
    how can i draw graph. - 7ed82f0.jpgimg src="http://i.fixya.net/uploads/images/7ed82f0.jpg" alt="7ed82f0.jpg" class="h_mi" />
    5. Drawing the Graphs
    • Press [GRAPH] to see the graphs.
    • If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions,
    • Here are the dimensions of thow can i draw graph. - 5c26e6c.jpg window
    6. ZOOMING
    The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
Posted on Sep 05, 2010
Syntax error for graphs
That hardly seems possible. Try graphing the function y=x.
There are a few ways to draw curves on this calculator
  1. Drawing functions
  • Type is y=f(X), the [X,theta, T] key enters X when pressed
  • Type POLAR r=f(theta), key [X,theta, T] enters theta w. pressed.
  • Type PARAMETRIC, requires an X=f(T) and Y=g(T) functions
  • Inequality graphing. You can also draw some functional inequalities such as y> 2X^2-3
  • Dynamic graphing (graphs where some parameter may be changing)
Drawing Relations
There are some other relation you can draw X=, X>, X< , and the drawing of general conics.
I hope that the foregoing remarks help you sort out the problem you are having. If they fail to do that, I suggest that you read the manual that shipped with your Prizm.
Sep 27, 2012 | Casio Prizm FX-CG10 Color Graphing...
When I try to graph, I get ERR:INVALID DIM I tried going to PlotsOff and I still can not graph
What happened when you tried going to PlotsOff. Did you actually execute the command?
If you executed that command and cannot graph then for some reason you are feeding lists or matrices as arguments to the functions you want to draw.
By the way are you drawing STATISTICAL GRAPHS or FUNCTION GRAPHS?
If you are drawing statistical graphs and you executed the PlotsOff command, it is normal you will not be able to graph because PlotsOff turns OFF the statistical graphs.
Here are a few things you can do:
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Aug 17, 2010 | Texas Instruments TI-84 Plus Silver...
Graph drawing problem
Read the first part of the answer to deactivate the statistical plots. No need to read the rest if you know how to do graphs.
Prepare calculator to graph
Setup Graph type
  • Press [MODE] key.
Drawing the Graphs
  • Here are the dimensions of the standard window
ZOOMING
You can also press [ZOOM] to adjust.
Apr 25, 2010 | Texas Instruments TI-84 Plus Silver...
Only graph one function at a time
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T), Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognize that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays Inequal RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Mar 18, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator doesnt graph two equation on the graph
  3. Press [ENTER].
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
  1. Press [Apps]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Mar 17, 2010 | Texas Instruments TI-84 Plus Silver...
When I put an equation into y=, there are arrows to the left, I don't know why
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T0, Y1=f(T))
  3. Press [ENTER].
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionality from the native OS and you can only draw a single graph.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionality will revert to the native OS
Mar 17, 2010 | Texas Instruments TI-84 Plus Calculator
I cant graph more than one equation at a time, it only allows me to graph one Y value at a time.
  3. Press [ENTER].
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. You recognoze that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
  1. Press [Apps]
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Feb 17, 2010 | Texas Instruments TI-84 Plus Calculator
I dont know how to graph
Turn calculator [ON]. If you do not see the menu icons, press [MENU]. Use the arrow keys to highlight the [GRAPH] icon.
An entry screen appears where you enter the functions you want to graph.
On the first line you have Y1= . After the equal sign enter 2[x] [X, theta,T] + 1. When finished press [F6: Draw] Your graph appears on the screen. If you see the axes, but no graph, press [Shift][V-Window] and press [F3:Std] then [SHIFT][QUIT] will take you back to the screen where you enter the functions to draw. There press [F6:Draw].
Hope it helps.
Sep 21, 2009 | Casio CFX 9850GA Plus Calculator
I need to make a graph on my CASIO CFX-9850Ga PLUS
Hope it helps.
Jan 28, 2009 | Casio CFX 9850GA Plus Calculator
How to draw graph using c++
there are nomerous way to make a graph in c++. you just have to now the code for it.. abse on my knowlegde there are on "for loop" statement that can be use in making a graph in c++.
Oct 08, 2008 | Computers & Internet
Texas Instruments TI-83 Plus Calculator Logo
137 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
