Question about HP Deskjet F4180 All-in-One InkJet Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are completely full, but the black ink still will not print onto any paper. I've tried pulling out the black ink cartridges and repeating the process but it still will not print black ink.
  • 1,218 Answers
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Sep 09, 2010
My printer isn't printing from the black ink cartridge -only color. I've replaced the black ink cartridge twice, so I know it isn't the cartridge.
Run a few "print-head-cleaning-cycles", to UNCLOG the ink-jets that should be spraying the black ink onto the paper.
Feb 21, 2011 | HP DeskJet 3740 InkJet Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
New HP 56 cartridge prints green
hello, are you sure its green, since this is a black in cart, only thing i can think of is machine not printing black , and the color ink cartridge is contaminated, this would be due to the docking area for the cartridge, on the left side of machine, there are 2 black rubber cups that the ink cartridges move over to seal. sometimes these cups have residual ink, which will contaminate the new inks. clean these black cups, and replace inks
Sep 24, 2010 | HP PSC 1210 All-In-One InkJet Printer
Ink cartridge
Try pressing the new cartridge onto a damp paper towel. Look for all colors to make a streak on the towel, if any color or black is missing it won't pass alignment. It won't pass alignment or let you print until you get all the colors working.
Apr 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
I just installed a brand new HP 17 color cartridge in my HP deskjet 845c (as it appeared that the old one had run out of pink and yellow color) and now the new one will only print out in blue. I took out...
One of the first things I would do is called "footprinting" the cartridge. Remove the cartridge from you machine and firmly press the bottom of the cartridge, the print head, onto a paper towel. Use your other hand to apply even pressure from underneath the paper towel. This, hopefully, will cause ink to bleed out of the cartridge and onto the paper towel. Be aware that you may get ink on you and take measures to prevent it if necessary. A good footprint from that cartridge should yield three small rectangles of the three colors in the cartridge, it is ok if they bleed into each other. If cyan is the only color flowing you can try moistening the paper towel with some warm distilled water and gently holding this against the print head for a short while (30 sec), again ink should come out. If there the cyan is still the only color to flow there is nothing more you can do at home. Return the cartridge if you can.
If however all three colors footprint well then it may be a driver and/or firmware issue with the printer. I would try reinstalling the driver first, then upgrading the firmware is an upgrade is available. Those machine are getting older and probably do not have as much support available as newer machines do.
Mar 24, 2010 | HP DeskJet 845c Printer
Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
Jan 20, 2010 | Canon BubbleJet i320 Printer
I can't get my black ink to print.
Could be the ink dried up. Unusual but happens sometimes. If you shake it does it sound like liquid in it?
If you recently replaced the cartridge, did you remember to take the tape off? (I know, sounds silly, but sometimes it happens.)
In the software, does it register that there's a blank ink cartridge installed?
Just a couple of ideas to get you going. Respond back and I'll work more with you.
Apr 07, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer stopped printing colour
Are you using Name brand ,new ink cartridges?
Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
Feb 14, 2009 | Canon i850 InkJet Photo Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
1,709 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
