Question about Sunbeam Dehumidifiers
Have a Sunbeam DHC-20M dehumdifier (42pint) that quit running by blowing the circuit breaker. Suspect it's the capacitor, but don't know how to test it since it has probably a dozen contacts on the end. Suggestions and/or source for parts??
  • Sunbeam Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It could be the cap. but probably it is the compressor that is toast...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
After the dehumidifier runs for 5-10 minutes it blows the circuit breaker
It sounds like there are other items on that circuit and the total load is a little above the circuit breaker rating. If not then probably the start relay is not dropping out.
May 08, 2014 | Dehumidifiers
KENMORE DEHUMDIFIER MODEL 580.51300100 DOES NOT RUN, NO POWER LIGHT AND NO FAN RUNNING ETC
First, check the source of the power to the unit, Has a circuit breaker in your home's circuit breaker panel been tripped? If so, unplug the unit, before resetting the circuit breaker. If that's not the case, check the outlet it's plugged into. It may be damaged or have a loose wiring connection. Be sure to turn the circuit breaker for that receptacle OFF, before removing the cover plate.
If all of the above checks out OK, check the water collection bucket, as it may need to be emptied and/or the bucket was not reinstalled properly or the float valve in the top of the bucket is stuck in the UP position, If so, jiggle the arm of the float valve to get to return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder and makes firm contact with the bucket safety removal switch.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Kenmore 54501 Dehumidifier
Our daewoo humidifier model dhc-250 date made 02/04 runs but seems like voltage goes up and down if on low or high fan and cont. cleaned all out ran great last year but now runs can hear power click up and...
Quite frankly, from what you described, you may need to have the refrigerant gas in the compressor drained and recharged. As. it sounds like the compressor wants to turn on, but lacks the ability due to low refrigerant or a faulty condenser switch. Either one can be repaired. But, if you don't have the experience to deal with it, it's best left to the pros.
Hope this helped you to troubleshoot and solve the problem.
Jun 21, 2011 | Daewoo DHC250 Dehumidifier
The amp blew in the DD50PC Delonghi and we need to replace it. What is the amp?
rmbm521 - I would like to help you, I have been offering solutions to humidifier problems for some time. But, I have never heard the term "amp", as would apply to a dehumidifier. In most general electrical terms "amp" or "amps" is the amount of electrical draw or use that an electrical appliance uses. It's short for "ampere".
I don't know where you heard it, read it or who told you that. But, they may have been referring to the circuit breaker , that's in your home's circuit breaker panel,. The one that feeds the outlet, the dehumidifier is plugged into. If that's the case, was your dehumidifier tripping one of the circuit breakers in you circuit breaker panel? If that's the case, they meant, the circuit breaker was not rated high enough to carry the load of dehumidifier, when it was in operation.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | DeLonghi DE50P Dehumidifier
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
When compresser comes on blows electric breaker
the outlet that you have the dehudifier plugged into has too many items plugged in on the same circuit and when the compressors kicks in it draws more amperage than the breaker load can hold thus popping the breaker either remove some electrical apliances from that circuit load or plug in elsewhere
Sep 14, 2009 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
624 people viewed this question
Top Sunbeam Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Sunbeam Dehumidifier Expert? Answer questions, earn points and help others
