Question about Sharp Televison & Video
I broght a 32 Sharp T.V. 1080P (LC-32D62U)wroks fine. Attached is VCR(RCA) & DVD(GE) works fine except when I record on the VCR. Play back is just snow?
  • 3 Answers
Try channel Line 1 or Line 2 on your TV and or VCR... not channel "3" if  you're using "RCA cords".  Also, make sure your VCR and TV are "SETUP" to look for composite input's rather than coaxial.
good luck!
thomseye
Posted on Mar 26, 2009
I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
Feb 17, 2011 | Sharp Aquos LC-32D62U 32 in. HDTV-Ready...
Need Remote fo RCA DRC8312N DVD-VCR Combo Thanks, Monte Haun mchaun@hotmail.com
My original remote malfunctioned for my RCA DRC8312N. I have purchased a RCA universal remote # RCR6473. I have used code # 3242 for the DVD code.It does almost everything that the original remote did except to open the DVD door. You just need to experiment with the onscreen info display in order to change title names and thumbnails etc. The remote also works great for other euipment functions as well as working features on my Sharp tv.
Sep 05, 2010 | RCA DRC8312N DVD Recorder/VCR
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i get to the input/video screen on the RCA F32672sb 32
If you have an old vcr hook the dvd player to the inputs on back of the vcr (RCA jacks) Run a coax cable from the "out" on the vcr to the back of tv. Turn the tv on channel 4 or 3 then put a tape in the vcr and push record then pause it. Or if the vcr has a tv/video button you can push or activate it and it should allow the dvd to play through to the tv.
Feb 10, 2009 | RCA F32672SB 32" TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Televison & Video Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
