Question about Cub Cadet 42 And 54 Inch Blade Operator's Manual
Drive belt routing for lt1042 - Cub Cadet 42 And 54 Inch Blade Operator's Manual
I have no power to the pto on my LT1042 mower I found broken wires and fixed the but still no power. Where are the fuses that would blow? I only found one fuse and its ok
Did you check for power at the pto switch? Start with checking that, then check the wire from the PTO switch to see if it has power all the way to the PTO clutch. If there is power to the clutch, and the belt is good and routed properly it's probably the PTO clutch.
Aug 11, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Belt comes off. idler pulley bracket doesn't seem to have enough tension on it. Bracket spring is still on. Maybe wrong spring? Just bought new belt and it went on way easier than old belt . is...
the new belt should be a hair smaller than the older one thus being tighter to put on, either the new belt is the wrong size or you don,t have the tensioner spring tight enouph, did you have to take it off at some point and just not get it back in the right hole
also make sure your routing the belt the right way around the pullies,if all that is good ten check the length on the belt
sounds like its just a matter of correct routing
Jul 31, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I forgot how i took my drive belt off my mower n i cant put the new one on its a LT1045 built in 04/26/07
I just got on www.cubcadet.com, went to the residental lawn mower section, used the side bar on the left hand side of the screen and clicked on Operators Manuals. its going to bring up a different window; for the model type in: Lt1045- for the serial number, just type in any numbers. after it loads, click on the first operator manual selection you see. after it brings the .pdf file, it should be pg.25 it has the diagram of the belt routeing. i hope this helps, i would have sent u, or loaded it on here, but its copywrited, so, you have to get it on your own. like i said tho...i hope this information helps u. Good Luck :)
Oct 08, 2010 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Serpentine belt diagram/ installation?
Fig. Accessory drive belt routing-2.4L engine
Fig. Accessory drive belt routing-2.7L (3RZ-FE/M) engine
Fig. Accessory drive belt routing-2.7L (2TR-FE) engine
Fig. Accessory drive belt routing-3.4L engine
Fig. Accessory drive belt routing-4.0L engine
Hope helps (remember rated this).
Jul 13, 2010 | 2005 Toyota Tacoma
Looking for diagram of serpentine belt
0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN U) engine
0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN S) engine
0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN U) engines
0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN S) engine
0996b43f80208c9f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.4L SHO engine
0996b43f80208ca0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Water pump drive belt routing-Ford 3.4L SHO engine
i wasnt sure what engine you had hope this helps good luck
Jan 15, 2010 | 2000 Ford Taurus
Need a diagram on how to refit fan belt
Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine without A/C
Accessory drive belt routing—2.0L (ABA) engine with A/C
Accessory drive belt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
Oct 31, 2009 | 2003 Volkswagen Passat
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
Cub Cadet 42 And 54 Inch Blade Operator's Manual Logo
304 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
