Question about Compaq Presario 1.6GHz AMD Sempron Mobile Wireless Notebook ( hp Refurbished - Model m2305nr ) (EC219UAR) PC Notebook
Compaq presario M2305NR
My screen was cracked how can i do to take off the cracked in screen?it is need to replace the LCD to avoid more damage?
  • 100 Answers
Presario 2500 screen wont come on but computer and lites are working
If you can't see any obvious damage, like a cracked screen, sometimes the module that illuminates the LCD screen just goes out. If it has a VGA port and you can get a computer monitor, plug the monitor in and see if it will boot up and run. It is possible that you might have the computer set up to boot to an external screen, but you would still see the Windows and HP logos at the boot up. If you see NOTHING at all, then try an external monitor. If that works, you may replace your screen...or not.
Aug 12, 2013 | Compaq Presario CQ62238DX Laptop
How to detect physical damages occured to laptop screen
If any Physical damage occurs to LCD then Some symptoms are -
-Black Spot
-Crack on Screen
-Screen Flicking Etc...
Jun 08, 2012 | Compaq Presario 12XL500 (470011-693) PC...
I have Compaq presario CQ60 notebook pc.When the lid of screen is moved it starts flickering. What should I do ?
This is typically caused by a loose cable inside of your screen. I do not suggest tinkering with it as you could possibly damage it more. In case you're feeling brave, here's a guide on how to get to the LCD on your model of laptop:
Again, I don't recommend trying this unless you have some prior experience with this sort of thing. Take it into a certified technician or call Compaq (HP) @ 1-800-HP-INVENT
Mar 31, 2011 | Compaq Presario Notebook
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Mar 06, 2011 | Compaq 449901-001 - HP Presario V6500...
Would a compaq presario v2000 screen be compatible with a compaq presario v4000 laptop. one of my cats juped onto my closed laptop and now there are two big black blotches and cracks across my screen so im...
Its not compatible. It has different screw listings then V4000.
If you could provide me the product No. which is at the bottom sticker of the notebook of your Compaq v4000 laptop then I can find the part no. for LCD screen which is less costlier and exchangeable.
May 31, 2010 | HP Compaq Presario v4000 Notebook
Compaq a900 screen missing bottom 33% of picture the rest ok
Any visible cracks in the screen? This sounds like a cracked LCD issue, had it happen on a LCD tv of mine a while back ... best bet would be to take it into a shop and have it checked.
Mar 24, 2010 | Compaq Presario Notebook
LCD screen replacements are available on the Internet. Make sure you select one that suits your laptop because the video and inverter connectors can be different between makes and models even though they maybe the same screen size.
Have a look at LCD Parts WEB site for parts, service and DIY info use this link :-
Sep 11, 2009 | Compaq Computers & Internet
I have a compaq presario cq50 215-nr. the lcd screen constantly flickers with colored lines going top to bottom. I can work if I press the screen down. I called HP they say that this comes under accidental...
I am sorry to tell you that the screen has been damaged and will need to be replaced. There is no work around/solution for a bad screen. Replacement is the only way to go. Sorry.
Sep 06, 2009 | Compaq Presario CQ50-215NR Notebook
How can i take it out yellow vertical line in my compaq presario
Broken Screen Or Not plugged in Properly,
Needs Replacing but be warned
Jan 23, 2009 | Compaq Presario M2000 Notebook
Computers & Internet Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
