Question about Splendide 2100 Vented Washer-Dryer
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
  • Splendide Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghgf
Posted on Sep 29, 2010
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Clunking noise when turning steering wheel going slow around corner
A lot of these Chrysler Town and Country vans had issues with the front stabilizer bar end links, usually you wont feel them move if you try to move them by hand, but they will make an awful noise clunk noise when turning or going over bumps slowly, i would suggest replacing the end links and that should take car of your clunking issue. Also the front lower control arm bushings separate as well and can cause this noise as well.... but i would replace the end links as a first step and go from there.... Hope this helps..
Sep 27, 2012 | 2003 Chrysler Town & Country
My 85 f150 is making a clunking noise when driving down the road. Sounds like it's coming from the front. The clunk starts when you start moving and and the clunking increases the faster you move. No...
Possible broken belt in one of your tires. Move the 2 front tires to the rear, see if the problem follows the tires. Or run your hand around the circumference of the tires to feel for a bulge. Other, more expensive problems could be in the suspension. A-arm bushings, or wheel bearings.
Nov 22, 2010 | 1985 Ford F150
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
When in spin made loud klunking and screaching noise. now will not work in spin cycle without making loud klunking noise
Pull off the bottom panel, (three 1/4" screws along bottom). Check for chunks of concrete hanging down, or in the bottom pan. I have seen the lower front counter-weights on the HE2 break off several times. If not, reach in and give the basket a hard spin by hand, if you hear clunking or grinding, or the basket feels loose, you have a bad basket brace (usually caused by slop in the rear bearing). You would need to replace the rear shell (comes with a pre-installed bearing) and the basket. Depending on age, these parts may be in warranty, check your manual.
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Splendide 2100 Vented Washer-Dryer Logo
416 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
