Question about Kitchen Ranges
I installed the range, stovetop works fine, but the oven controls, timer display etc. are not lighting up or functioning
  • rstanbau May 18, 2008
    Thank you - you were spot on. The neutral was disconnected in the junction box.
  • DRAGONFLY13 Jul 09, 2008
    MY OVEN WORKS BUT THE LIGHT PANEL DOES NOT. I CAN NOT SEE HOW HOT THE OVEN IS OR ANYTHING ELSE HELP
    Genius:
  • 1,073 Answers
Check for a votage problem ie loose nutral, clock has to hve 120 volt on the control board of the oven from main terminal block , if it doesnt it will not work if it does then replace the control
Posted on May 11, 2008
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
The control panel does not work at all for our oven, the time is displayed, but the oven will not turn on. The range works fine. I think I need to reset the control panel? for model GE Profile J2B918SELSS
If there is no reset on the control panel, which there normally isn't, you will probably have to get a new one if you wish to use auto. function in the future. If you don't require auto. function it is a simple procedure to by-pass the timer so the oven will work. With the timer by-passed the clock will still function.
Feb 11, 2011 | General Electric J2B918SELSS Stainless...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven, oven light and oven led display will not work
that sounds like an erc[electronic range control] or clock timer etc. You can check power supply to it but chances are thats what you need.
May 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
LED display not working
Did somebody use the control lock by accident. Here is how to disable it. Hopefully it will work: The Control Lock feature shuts down the control panel pads to avoid unintended use of the oven. The Control Lock feature may be used either when the range is in use or turned off (for example, during cleaning). To lock/unlock control: Before locking, make sure the oven, the timer, and Timed Cooking are off. Press and hold the START pad for 5 seconds until ?CONTROL LOCK? appears on the display. Repeat to unlock, and ?CONTROL LOCK? will disappear from the display. Hope this helps Jason
Sep 04, 2007 | KitchenAid KESC308LSS Electric Kitchen...
Kitchen Ranges Logo
155 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
