Question about Citizen Watches
How do I adjust date and days of the week? - Citizen Watches
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Hi, Without specifing model and caliber, follow these rules. You need the Caliber number to get instructions. Most setting instructions are near the front of the manual, between pages 3-9. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Posted on Sep 08, 2010
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
I have Timex SR 920 SW watch, how to adjust the date and day?
Adjust the day of month (1-31) by pulling the crown pin out part way, and turning the pin counter clockwise, incrementing the date arm. Counterclockwise does nothing.
To adjust day of week (Mon-Sun), pull the pin out and rotate to turn minute/hour hands. Each time you pass 12:00, the weekday hand will increment by a half step.
May 01, 2011 | Timex Analog Metal Field 40051 Watch for...
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Invicta model 4562 7750 valjoux automatic movement. Day and Date are difficult to set. Move crown to second (B) position, sometimes the day of the week adjusts, then the date will not adjust moving the...
Hi Friend,
Please check with the below link,which gives the detailed information about the Invicta Watches.How to set the Date and time in your watch.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
If you have any Clarification please write back to us
Regards,
Aysaam
Jun 13, 2010 | Watches
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 | Watches
Watches Logo
240 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
