Question about GE Dishwashers
My dishwasher is a Profile Quiet Power II and is 8 years old. There is one person in my household, so it has not had a lot or wear. The issue is that the flatware and glasses do not come out clean. The flatware is often smudged and the glasses are cloudy. I have changed detergent several times and adjusted the settings and hot water. There is a self-cleaning filter. I am contemplating buying a new dishwasher but wonder if I would benefit from a service call.
  • ckrieger_200 Sep 09, 2010
    Thanks, Daniel. I think I will work with this some more. Your suggestions were excellent. I just purchased Affresh from a local dealer who was convinced that I did not need a new dishwasher. How do you add vinegar to the rinse water? Do you just open the machine at some point? I do have a whole-house water purification and softening system in my house. At one point I really increased the heat for the water. Are you saying that it not necessary?
    Thanks again,
    Carole.
  • 4,323 Answers
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed. It may also be due to mineral deposits on the heating element. Inspect the heating element for any deposit and scrub it with a soft brush when the dishwasher is unplugged. Try filling detergent cup half way and use white vinegar after the wash cycle is complete, run a complete cycle. Run a cycle with glasses and see if there is any difference. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle.
Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps. Sometimes, the dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 03, 2010
  • Daniel Scott
    Daniel Scott Sep 10, 2010
    Hi Carole,
    While the dishwasher is in the final cycle, pause it and add some vinegar. Also try cleaning the heating element if you are able to access it. And, high heat sometimes damage the heating element and also causes the minerals to deposit on the element. Use a cup filled with vinegar and let it be there for one cycle. Most important thing to remember is that you use half detergent than you use normally . Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
    Thanks
    Daniel
8 year old jade dishwasher has suddenly become very noisy
Eight years is a lot of dishwashing. There are hoses, belts and gears- all of them wear- and the noise is part of the result. Especially when it works hardest.
I doubt it can be repaired for less than its is worth
Time to visit Amazon
Mar 08, 2014 | Jade Dishwashers
Won't start?
Good Morning Lisa - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Jun 13, 2013 | Electrolux Dishwashers
Whirlpool Quiet Wash II
there might be connection problem with those buttons you've tried
Jun 04, 2013 | Dishwashers
I have waited 24 hours for a response to my problem about the Whirlpool Quiet Power II dishwasher leak. Please respond. Thank you. Clisten Wells Indianapolis
Clisten, maybe no one had an idea for your issue...You did not mention what the issue was, specifically, in THIS post....be sure that you are using the correct detergent, anything but automatic dishwasher soap will cause leaking...
Mar 22, 2011 | Dishwashers
Hello ... We have a GE Quiet Power 3 Dishwasher -- only two years old. Dishwasher won't start ...and we are getting an 1h code. What is a 1h code? The manual does not provide any code...
Try unplugging the unit for several minutes if that does not fix the issue you will need to replace the main control board to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dishwashers
NORMAL Wash light is blinking and I can't CANCEL wash. GE Quiet Power II PROFILE dishwasher. Started a normal wash and a few minutes into it the NORMAL light started blinking and can't find a way to reset.
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Jun 09, 2009 | GE Dishwashers
Dishwasher: GE Profile Quiet Power II
the product model name and/or number?. and I could easily find a guided manual for you.
Dec 28, 2007 | Computers & Internet
Quiet Series 100
It sound like a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if pump spins when it should force the water up into the sprayer arms. In case it doesn't spin you should replace the pump. Good luck !
Sep 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
