Question about Braun Series 7 9585 Hair Trimmer
Repair / replace trimmer on braun 9585 shaver
  • Braun Master
  • 1,598 Answers
This part is only available from a Braun repair center. You can call a repair center at 847-869-7755
Posted on Sep 04, 2010
Testimonial: "Provided precisely the information I needed."
  • brector3_not Jan 13, 2011
    A BROKEN / MALFUNCTIONING HAIR TRIMMER IS A KNOWN ISSUE WITH THE 9585 BRAUN MODEL. THE REPAIR PART NEEDED IS AVALIABLE ON EBAY AT MORE REASONABLE PRICING THAN A BRAUN REPAIR CENTER.
  • Richard E. Jul 04, 2011
    I've got the part. How do I get the head off in order to replace the trimmer?
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
Why does my shaver turn off automatically when I turrn it on?
Replace the razor head making sure it sits secure so it won't block the cover and let it spin freely.
Oct 21, 2013 | Braun Series 7 9585 Hair Trimmer
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
Feb 03, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
My Braun shaver trimmer is loose and does not function Can this be repaired? The trimmer has fallen out making loud noise.
These trimmers can break internally and require replacement. You will find the replcement for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For installation, you will find a helpful video at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Jan 04, 2011 | Braun 8585 Electric Shaver
I have a Braun 760 razor. The two electric contacts on the charging/cleaning base no longer make good contact with the razor. One of them seems to have some corrosion on it and prevents the razor from...
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
Sep 28, 2010 | Braun Series 7 9585 Hair Trimmer
Trimmer on Braun Pulsonic shaver won't stay shut?
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Aug 19, 2010 | Braun Pulsonic Rechargeable Cordless Men's...
The thin plastic internal piece that is needed to open and close the trimmer of my Braun #9585 has broken. Where can I get a replacement.
Aug 18, 2010 | Braun Health & Beauty
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
The trimer on my 9585 appears to be broken. It will not stay open, nor will is close properly.
This is a common problem with your model shaver. The part you need is not available to the consumer and you would not likely be able to install it if you could buy it yourself. You will need to contact a Braun Service Center for repair. If your shaver is less than two years old, it should still be covered under warranty.
For Braun Authorized Service Center call 847-869-7755
Mar 27, 2010 | Braun Health & Beauty
Braun Series 7 9585 Hair Trimmer Logo
2,961 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Robin Hill
Robin Hill
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
