Question about Western Digital My Book World Edition 1TB Remote Access Storage System
Bought a WD MyBook 2Tb hdd. I have Z:\public and Y:|downloads visible on a desktop PC' and a netbook. X:\Shared_Files is one I set up on my PC and I can see it on my PC but I cannot map the netbook to it. It asks for a username and password and when I input even admin and the admin password it refuses to map - " \\MyBookWorld\Shared_Files is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Discnnect all previous connections to the server or shared resource and try again." Same message even if the PC is off and am using the netbook only. The PC maps to it no problem. Never asks for a password. Configure when using the netbook asks for username and password when trying to map a drive letter, say X like the PC) on netbook and fails with this error. HELP!!!!
SOURCE: permissions of access
Posted on Oct 06, 2007
SOURCE: Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Posted on Dec 18, 2007
SOURCE: Can't access My World Book 1TB through my browser.
Hi Vonnossa
I had exactly the same issue after removing the MioNet software. My device is connected to a router that assigns IP addresses (DHCP) and can easily be accessed using explorer and by mapping the drive so that its available on startup.
The solution I found is as follows.
The unit has a default reset button that will reset the unit User Name to "admin" and the Password to "123456" Without the quotation marks.
The button is recessed in a small hole between the power connector and the network connector on the back of the unit. Its much the same as the small hole on a CD/DVD Drive used to remove discs from a PC that is switched off. You will need a paper clip or similar to reset the device.
Step 1. Switch off the unit and remove all leads.
Step 2. Insert the paper clip into the small hole mentioned above and press (not to hard though)
Step 3. With the clip still in the hole, connect the power lead and switch the unit on.
Step 4. Wait until the circular power button lights up ( this can take anything up to a couple of minutes). Once lit count to 10 and remove the clip.
Step 5. Re-connect the network cable and return to your PC.
Step 6. In your browser type in "wdstorage" No quotation marks.
Step 7. This will open the shared storage manager page. select your option and when it prompts for username enter "admin" and for password enter 123456
Once done you can change usernames and passwords as required.
Good luck
Posted on Dec 29, 2008
  • 17 Answers
SOURCE: Can't map network drive WD Blue ring edition
The Failed Mount issue is usually caused by Internet Security settings. The most common way to resolve it is to add the following files/ports to the exceptions list of your firewall(s) -- in some cases you will need to add it to the Windows Firewall, even if you have another Firewall installed as well:
MioNet.exe (C:\Program Files\MioNet\jvm\bin\MioNet.exe)
MioNetManager.exe (C:\Program Files\MioNet\MioNetManager.exe)
ServiceStatusGui.exe (C:\Program Files\MioNet\ServiceStatusGui.exe)
These ports are also required for MioNet to create a drive-letter for remote drives:
TCP In/Out 443
TCP In/Out 445
Posted on Sep 18, 2009
  • 696 Answers
SOURCE: I can no longer access any of my files on my wd1tb network drive
It sounds like either the NAS enclosure or the drive(s) inside have failed.
If the enclosure has failed and you don't have any crucial files on it that you don't already have elsewhere, contact for a warranty replacement.
If the enclosure has failed and you DO have important files on it, try having your local PC shop move the hard drive(s) into a new enclosure, if that works you're done, buy the new enclosure.
If the new enclosure fails, your drive is damaged and you will need a pro to help get back your files. If this is the case, reply back with you location(Country, State and City) and I will pass along recommendations for your neck of the woods.
Hope this helps FixYa,
Posted on Oct 25, 2009
I own microsoft office 2007 how can I download it onto my new hp mini110 which has no cd slot
"I have a netbook with no optical drive. How can I install Microsoft Office? A friend says I have to either buy Office as a download from Microsoft or get an illegal download - don't like either of those options. " Charles C from Iowa among many have asked this question.
There are several options for installing software onto a computer with no CD / DVD drive. We'll focus on Microsoft Office (as usual) but the same techniques can be used for almost any programs.
All these suggestion boil down to a simple truth - you can copy the contents of the Microsoft Office install disk to a folder which can be accessed from the netbook.
We have plenty of other netbooks on Office tips in our feature: Using Office on Netbook computers. Like this article, our feature was written on a netbook computer, so the advice is from hard personal experience.
Install disks are NOT that special There was a time when install disks were specially made so you could not copy them easily but those disks are rare these days. The installation files for Microsoft Office can be copied just like other files.
What really matters is the Product Key that's supplied with your purchase - it's that 25 character key which allows Microsoft Office to work normally. See What happens if your product key is stolen?
USB memory stick The easiest option is to copy the entire contents of the install CD to a USB memory stick or portable drive then plug that 'key' into the netbook.
Make a folder on the USB drive called, for example, Office 2007 Standard install.
Then copy the whole CD/DVD (sub-folders and all) with the root folder of the install disk copied to the new folder on the USB drive.
Office install disk copied to folder on removable drive
When you plug the USB drive into the netbook, navigate to the install folder (ie what was the root folder of the original CD/DVD).
Double-click the setup program or right-click autorun and choose Install. This will start the install process just as it would from the CD/DVD.
Share a CD/DVD drive On a Windows network, any drive can be shared and 'seen' across the network by other authorized computers.
Go to the desktop computer, right-click on the CD/DVD drive and select Sharing (the exact menu wording depends on your version of Windows) then share the drive with appropriate permissions.
On the netbook computer, go to the Network option on the Start menu. Navigate to the desktop computer then the shared CD/DVD drive. You can then see the contents of the install disk, click on setup or autorun (as above) and the installation will begin.
Apple promoted a 'special' remote CD feature when they released the Macbook Air. It was hailed in many quarters as a wonderful innovation, despite the fact that Windows users have been able to do the same thing for years.
Copy to netbook across the network If setting up the CD/DVD as a network share doesn't suit, you can simply copy the install disk contents to a new folder on a desktop hard drive which is shared and accessible from the netbook.
On a Vista desktop machine the easiest option is copying to one of the 'Public' folders then make sure those folders are shared with the local network. The netbook computer can 'see' that shared folder on the desktop machine and you can install from there.
Alternatively, copy from the desktop CD/DVD to the netbook computer. Make some folders on the netbook shared with write permissions then open Explorer on the desktop computer navigate to the shared folders on the netbook. Copy the contents of the install CD/DVD from the desktop computer to the shared folder on the netbook. Install from the netbook folder.
Plug in a CD/DVD drive There are plenty of cheap USB CD/DVD drives available which you can buy to plug into your netbook. However, as you can see, there is usually no need because you can access an optical drive from a desktop computer via the local network.
Repairing Office In the olden days (ie a decade ago) if Microsoft Office had problems you'd have to dig out the install CD and reinstall.
For the last few versions of Office (Office 2007 and Office 2003 at least) that's rarely necessary. When Office is installed a copy of the key installation files is put in a hidden folder - if (when) Microsoft Office has a little nervy an auto-repair system should start and restore files from the source. Re-using the install disk is less common these days.
Article posted: Wednesday, 27 May 2009
Jun 17, 2011 | HP Computers & Internet
I just bought 2TB my book essential, I thought it would provide an extra drive for my Dell PC, but it just seems to be for storage, can it be used like an additional drive. For example keep a file on it...
The "best" usage for an external disk-drive is to make one more "copy" of all your important files & E-mail & music.
So, if your computer "dies", you still have one copy of your files on the MyBook.
Fix or replace your computer, and copy the files from the MyBook onto the repaired/new computer.
Or, if your MyBook "dies", you still have one copy of your files on your 'C:' drive,
and you can fix/replace your MyBook, and copy your files onto the "revived" MyBook.
Nov 10, 2010 | Western Digital My Book Essential Edition...
Write delay message could not save all data for file F:\$FMft when doing back up using WD my book premium II 2tb raid split
I presume that Windows assigned 'F:' to your WD MyBook.
Windows was trying to write the 'MFT' ("Master File Table") file, to the 'F:' drive, but it failed to complete.
Is the drive "full" ? Can you delete some files, and try again to doing your "backup"?
Oct 11, 2010 | Microsoft Windows XP Professional for PC
WD Mybook 320. Detected by computer, files all shown, but cant ac
Download the software Recover My Files , google for it and install the software. U can recover with the instructions in the software. it is very easy. U will get the files..
Sep 16, 2009 | Western Digital Passport WDXML800UE...
My Advent 4211 netbook connects wirelessly to the Internet through my Desktop and a Belkin router. How do I allow the netbook to see the files in the desktop?
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Aug 16, 2009 | Advent 4211c Notebook
I am having a problem copying large mkv files from a WD 2TB mybook to another WD 2TB mybook. they are both formatted to NTSC. I had no problem loading the first drive but the second one is giving me fits!
In order to fix this problem, be sure that the drive is formatted to NTSC. Mine was, however, when I started loading mp3 files to the drive first, it somehow got reformatted to FAT32. I don't know how, but it did. Copy your mkv files FIRST!
Apr 14, 2009 | Western Digital My Book Essential 1TB...
No space error
This is due to the file transfer limitations bound by the file format FAT32 (no files larger than 4GB and no folders that contain more than 1000 files). Try formatting the drive to NTFS.
Dec 30, 2008 | Western Digital My Book Essential 1TB...
Mionet is not showing up
was this working before.or just after installing it is not working.
Aug 21, 2008 | Western Digital 500GB My Book World...
Western Digital My Book World Edition 1TB Remote Access Storage System Logo
264 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
