Question about Uniden BC350C Base Scanner
Scanning programmed channels
Is it possible for me to only scan the programmed channels on my scanner without listening to all 280 frequencies, for example the 20 programmble channels on the fire/ems bank?
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
Posted on May 13, 2008
  • Ziesenis May 13, 2008
    Correction....lol...after having this scanner for over a year I just discovered you can prorgam also into the Fire/EMs and Police banks....oops...
Channelslockedout
Hi Barney,
I take it that you have frequencies programmed into the scanner, so this is the solution to your problem.
On the keyboard of your radio scanner you will find a button marked L/O or L/Out, when your scanner is in scanning mode, press the Mon or Hold button, this will stop it from scanning.
Now select the channel of your programmed frequencies, starting with Channel 1. To do this press Hold followed by 1, if this channel shows a L/O icon on the LCD screen, press the L/O button and the L/O icon should go out. continue through each channel, until you undo the L/O from each channel by following the steps I have described above, once you have removed the L/O icon from all the channels that were locked out you can then press the Scan button and you'll be listening to the frequencies that you programmed into your scanner.
Note: If you have not programmed any frequencies into your radio scanner, then you will not be able to hear anything, as nothing programmed to hear and L/O is the default setting on all channels, until each one is programmed with the frequencies of your choice.
How to Program a frequency?
Press Prog button, select channel to store frequency, E.G:Ch:1 168.5000
Remember to always press the (.) decimal button in the correct place, else you will get ERR message on the LCD, now press Enter button, you now have the first frequency stored in you radio scanner on Channel 1, now press the Delay button, so that it doesn't start scanning for 2-3 seconds after a transmission is received.
Continue with the above setup one channel at a time until you have programmed your radio scanner to your liking.
I hope I have helped you in finding the solution to your query.
Regards,
Peter
Feb 22, 2013 | Radio Shack Pro-2096 Base Scanner
How to clear old codes of a scanner
I don't know of any global RESET function for your model scanner, but you can clear/delete the frequency (they're not codes) in any channel by programming 0 (zero) into the channel. Also, programming any new frequency into a channel automatically deletes/overwrites the previously programmed frequency.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 01, 2011 | Uniden BC248CLT Base Scanner
How to delete channels on the bc80xlt scanner
You can temporarily lock out a frequency by pressing the L/O key while the frequency is displayed, or can delete it by programming 0.0 (zero point zero) into the channel. Also, programming a new frequency into the channel will automatically delete/override the old frequency.
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Dec 16, 2010 | Uniden BC80XLT Handheld Scanner
How do i delete a frequency already programed? and can i get a frequency at 46.5000?
Programming a new frequency into a channel automatically deletes and replaces a frequency already programmed. Or, to just delete, and leave an unprogrammed channel, just program 000.000 into that channel
Yes, you can program/receive 46.5MHz. The full tuning range of your scanner is 25-54, 108-174, 406-512MHZ.
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Nov 05, 2010 | Uniden BC72XLT Handheld Scanner
How to porgram bc140police scanning radio
First, you'll need a list of frequencies to program into the scanner. The BC140 memory is limited to just ten channels, so you'll need to select your coverage carefully. For a detailed database of active frequencies in your area, visit:
Once you have your frequency list:
- Power the scanner ON.
- Press the Manual key to stop scanning.
- Select the channel to program (1 through 10) by either entering it on the keyboard and then pressing Manual again, or by repeatedly pressing the Manual key to advance through the channels.
- Enter the frequency, including the decimal point (e.g., 156.055).
- Press Enter (E) to save the frequency in the scanner's memory.
- Press Manual to advance to the next channel and enter your next frequency.
When you finish programming, press the Scan key to start scanning.
If you enter an out of band frequency, one that is not covered by the scanner, the display will show E for error.
Bill B.
Nov 01, 2010 | Uniden Radio Communications
I have a Uniden Bearcat 140 10 channel scanning radio and need to know how to program it. Can you help? The Model is BC 140 and the serial # 73061234 It was my dads and he passed on and I want to...
Your scanner is a basic 10-channel "oldie" and it's fairly simple to program and operate. To enter/program a known frequency:
- Power the scanner On
- Press MANUAL to stop scanning
- Press MANUAL repeatedly to advance to the channel that you wish to program
- Enter the desired frequency, including the decimal point (e.g., 156.225).
- Press E to enter the frequency into memory
Press the MANUAL key to advance through the channels, and press SCAN when you're ready to listen.
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Oct 20, 2010 | Uniden BC244CLT Base Scanner
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
Bill B
Apr 11, 2010 | Uniden Nascar BC-92T Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
I dont no how to program my regency z30 scanner
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you wish to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Apr 07, 2009 | Office Equipment & Supplies
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
May 31, 2008 | Health & Beauty
Uniden BC350C Base Scanner Logo
80 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
