Question about HP PSC 1510 All-In-One InkJet Printer
Hp psc 1510 won't print
I have installed new toners. The allignment page prints perfectly fine, but when you go to send anything to the printer, it simply sits idle. Nothing is sitting in que.
I uninstalled all the printer software and reinstalled the most current driver from the net and still nothing.
Someone suggested that the printer is just "fried" and I don't buy it because if fried the allignment page would not print.
Help if you can...
  • 3 more comments
  • runn262 May 12, 2008
    I have swapped out several cables, I have taken it off line and placed back on. Again the alignment sheet prints just fine, but it will not accept a job from my PC.
  • runn262 May 13, 2008
    So if/when I delete all the other printers (laser, pdf printer, fax printer, etc) then what? I will have to reinstall the drivers for all of those correct?
    And if when I delete them all and if the HP then works, then where am I? Not able to use the other printers that I do use?
  • daram Nov 13, 2008
    I have the exact same problem- that first alignment sheet prints great every time I readjust, unplug, or restart the printer... but all documents remain pending and unable to print. Help?
    and I did try all listed options
  • soncaliu Nov 17, 2008
    HPPSC 1510
    Scans kay prints off test okay but will not print from PC
  • 62 Answers
Did you check if the printer online? did you check if the printer cable is ok?
Posted on May 11, 2008
  • Lucas Bester
    Lucas Bester May 13, 2008
    when unplugging the usb cable and re-insert it, is there any activity on the screen eg: printer found or doesn't req the device ?
    Guru:
  • 1,342 Answers
Go to Start, Printers and Faxes. Right click on your printer and make sure that it is set as the default printer. Delete any other printers that may be listed in there.
Got to Control Panel, Administrative Tools, Services. Stop and re-start the print spooler service. Make sure it is set to automatic.
  • Georgia B
    Georgia B May 12, 2008
    Make sure the "Print Spooler" service is running in "Control Panel", "Administrative Tools", "Services". Double click on the service to open the properties window. Set it to automatic and hit "Start"
  • Georgia B
    Georgia B May 13, 2008
    Don't delete any printers that you know you DO use. Just delete anything that you know does not belong in there. Did you try setting it as the default printer? Did you check the print spool service?
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Printer prints test page before every print job
replace all carts with new HP carts to get a sucessful alignment
Apr 20, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP 1510 PSC prints diagnostic page, alignment page fine. Will not print anything else. I have already tried reconfiguring and cleaning the heads. No success
It was a "refilled" cartridge and not a new cartridge. For some reason the refilled cartridge was empty after being filled recently. Not sure why or how. A new replacement cartridge fixed the problem.
Nov 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
Print page every time when printer is switch on
make sure you don't have a sticky button on your printer that is always sending an allignment printout. otherwise, uninstall the printer and re-install it again. try resetting the printer also
Jun 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1510 prints reddish-pink color
the photo come out pink and i buy yesterday can you help me hp 1510
Oct 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Allignment
when you insert the new cartages then when the align page will print put it in the scanner and scan it once the align page will be scanning it will not print the align page up to you not change the cartrage
Jul 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Replaced ink cartridges and check ink cartridges still blinks
If your software is installed correctly when your printer, connected via USB?, the printer icon in the system tray can be clicked and bring up the printer utility. From there or at the printer control panel you can instruct it to align and or clean the print heads.
Worldvet
May 31, 2008 | HP PSC 1510 All-In-One InkJet Printer
Only printing partial page
hp psc 1315 printer dead due to lighting send me circuit drawnig
Dec 12, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
1,068 people viewed this question
Ben Johnson
