Question about Topaz Systems SignatureGem T-L755-HSB (ZTL755HSB)
Wires are frayed and need to be replaced - Topaz Systems SignatureGem T-L755-HSB (ZTL755HSB)
  • 221 Answers
I think you should replace the wires... because they're frayed.
Posted on Sep 03, 2010
Solucion Para el Codigo P0153 en ford F 150 motor 8V
A code P0153 may mean that one or more of the following has happened:
  • The oxygen sensor is faulty
  • The wiring to the sensor is broken / frayed
  • There is an exhaust leak
Dec 17, 2014 | 2004 Ford F150
Sennheiser HD 205 Headphones. My cable has had its fair share of pulls and tugs over time and finally the left ear stop working. By fiddling with the cable i was able to get sound from the left ear, but...
Hi, Ian, If you have soldering experience, you might be able to replace it by yourself. If you remove the portion of the wire that is frayed and replace it with new wiring, it might work. If you feel comfortable doing this, I would say go ahead. However, it might be just as cost-effective to take it to a local audio-repair shop and have them do it. I have had multiple sets rewired myself, and it has cost less than $20 each time. Either way, it should be a relatively easy and cheap fix.
Feb 25, 2011 | Sennheiser HD 205 Professional Headphones
Have an old 1950's fridge and need it restored. Where do I start? Suzanne in Sydney southwest.
Check all electrical wiring to make sure there are no bad wires - this can cause fire hazard. Replace the old or frayed wires. Pull the motor and compressor out and check independently.
Oct 31, 2010 | Refrigerators
Crankshaft position sensor replacement 2005 pt cruiser
it helps if you can lift or jack up the vehicle. be sure & use jack stands. it should be above oil filter on engine block under exhaust manifold. look for a sensor with one bolt holding it on. also check for frayed wires rubbing on cv shaft. sometimes all they need is fix one frayed wire
Sep 12, 2010 | 2005 Chrysler PT Cruiser
Fuse keeps poping for the speedometer / cruise control ...i replace it but as soon as i turn the key on it pops.
wiring needs to be replaced they may have come frayed by viberation and rub against each other.the wire harness may be close to speedo cable.
Aug 29, 2010 | 1999 Ford Windstar
I need to replace frayed wire
You can get a new plug from any hardware store and replace the plug you have . 2 prong or 3 prong to match the original, cut the wire back just enough to get away from the frayed part ,.. when connecting the wire , curl the bare end of the wire around the screw in the direction of tightening the screw, clockwise .
thoughts?
Please Vote !!
May 14, 2010 | Breville BBL600XL. 5-Speed Blender
I have the WFW9150WW00 duet and the front load washer wash light blinks and it will not wash. What to do? My wash room only has a cold hook up. Does this type machine have to have a hot connection?
I have the WFW9150WW00 whirlpool duet, I start the cycle and it starts to wash and then starts beeping, I push the start button and sometimes it will finish the cycle fine and other times it will just shut off like it is done and clothes are dripping and has never finished the other cycles. What is wrong
Feb 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cusor wont appear on screen after setup
I had this problem too, and I found out what was wrong. I hope it's as easy of a fix for you as it was for me, the only thing is if the reason is the same. If your Wii sensor bar is not wireless, carefully check the wire for frays. Once I brought my Wii to my cousin's house and had the same problem you have. We did everything we could think of, then I checked the wire. It was frayed. I couldn't understand how it happened because we barely ever touched it, but we just replaced the Wii bar and everything was fine. Even if you can't see any frays on the outside of the wire, it's possible that the damage is on the inside of the wire. Try testing another wii bar on your system if this happens or if you don't find any visible frays. I hope this solves your problem. I know how frustrating this can be. Let me know if everything worked out!
Mar 11, 2009 | Nintendo Wii Console
Laptop adapter wire frayed
you could try some of that shrink wrap that you heat up that shrinks to covering wires after a repair a ( the proper name escapes me at the moment)... split the covering ... wrap it around the frayed part and heat it up.
Radio shack etc has the part
Jan 10, 2009 | Dell 12V ~ 21V AC Power Adapter for...
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Topaz Systems SignatureGem T-L755-HSB (ZTL755HSB) Logo
48 people viewed this question
Top Topaz Systems Computers & Internet Experts
David Payne
David Payne
Are you a Topaz Systems Computer and Internet Expert? Answer questions, earn points and help others
