Question about Karcher G3025OH Pressure Washer
How do I fix a pressure washer that will not build up pressure quickly and when it does reach high pressure, the pressure quickly drops to a lower pressure (more typical of the pressure found in a garden hose)
  • gtownsend Sep 04, 2010
    I had checked the hose on the inlet side of the pump. Someone had removed the screen, and I don't know if there has been stuff in the water running into the pump and has done any damage or not. this washer's water is supplied from a poly tank via a Honda pump which pressurizes the 3/4 inch hose to the pressure washer. Water sitting in the tank grows algae, etc. is it possible that there is stuff stuck in the pump that can be cleaned out somehow?
  • gtownsend Sep 06, 2010
    i will try the vinegar solution. thanks
  • 2,841 Answers
It can be the inlet filter where your garden hose connects is clogged, so check that first. Also make sure that the hose is connected tightly and not pulling in air both at the inlet and outlet. Remove the spay nozzle and use a pin to make sure it is clear on and debris. Pull the trigger wait until you see a constant flow of water, and all air has been purged from the system. Then attach the high pressure nozzle. Black nozzle is for low pressure. Also make sure you are using at least a 5/8" garden hose and no smaller with the water turned on fully. Check the hose for kinks and obstructions. If all this checks out you may have calcification. Use the black low pressure nozzle and a gallon of distilled vinegar and inject it through the unit to remove any calcification. If none of this solves your problem then there is a problem with the pump itself and you will need to call Karcher for repair or replacement of the pump. Although your unit has a thermal relief valve, you should not run this unit for more than 5 minutes without pulling the pressure washer trigger or it will overheat and damage the pump. If you find you need a new pump here is one for $142. http://www.pwoutlet.com/KARCHER_LEGACY_26_30_PRESSURE_WASHER_PUMP_p/8.920-004.0.htm
Posted on Sep 04, 2010
  • NOT ME Sep 04, 2010
    It is possible, but the vinegar should clean it out. The pump may have been damaged due to the inlet screen being removed and some debris entering the pump.
High pressure wont shuy off
do you mean it keeps trying to build pressure even when you release the trigger on your wand???that is a problem with your unloader....also checkout your shutter valve and replace the oring on it. You will need the diagram here to know what parts Im talking about Pump Breakdowns and you can order parts here Pressure washer parts catalog quick links Pressure Washers High Pressure...
Jul 19, 2014 | Annovi Reverberi 2400 Ar Pressure Washer...
Power boss pressure washer stops when trigger is released
The unloader on yoru pump is bad.. Pressure washer parts catalog quick links Pressure Washers High Pressure... go here with your model number on your pump and they can guide you to your new unloader. Good luck
Apr 17, 2014 | Powerboss 20309 3,000 PSI 2.5 GPM Gas...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Wont reach high presure
The water admittance valve is stuck. Remove the valve spool from the bore and clean the bore with crocus cloth on a dowel rod. Replace the Orings and lube with a bit of plumber's grease and re-assemble. The Orings get dried out and deposits build on the walls of the bore. The valve is usually at right angles to the engine shaft on the back of the pump where the hose connects.
Jul 13, 2011 | Karcher 4000 PSI 36 GPM Gas Pressure...
The pressure washer starts but no water will pass through. The model is RX2600.
Common problem. The water admitance valve is stuck in the bore. The valve lets in more water when pressure drops and when wand is closed the pressure builds and the incoming water is blocked. Remove the valve spool and clean the bore with crocus cloth on a dowel rod. Replace the O Rings and lube with plumber's grease and re-assemble. Often you can buy an O Ring kit for the unit. Deposits build up and stick the valve spool at the high pressure end. The valve is usually crossways to the shaft and right where the water input is connected.
Jun 29, 2011 | Honda 2500 PSI Gas Pressure Washer
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Karcher G3025OH Pressure Washer Logo
512 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
