Question about Technics Audio Players & Recorders
My technics sa-ex 300 wont power up it keeps saying over load can i fix it?
  • 53 Answers
Unplug the speakers and try it again. If it still does it then one amp channel is probably blown
If it stops then the speaker is faulty or wire may be shorting
Posted on Sep 04, 2010
The fuse blow up and now say overload
Hello, Replace the blown fuse with same current rating. Also remove the load and power it on ,if it does on , then you reduce the numbers of load that was initially on the receiver....
May 19, 2010 | Technics SA-EX400 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
My technics intergrated amplifier says over load
overload is protection from very big signal input-or high current output.
1-keep your input signal between -10db-----to 0db.
2-confirm that amplifier power is greater than total power of loudspeakers by 20%(if loudspeaker total power is 8 watt-amp watt must be 10 watt at least.
Nov 30, 2009 | Technics SUV500 2-Channel Amplifier
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
Cooling solution for technics volume controlled fan
fit a case fan from an old p.c to the 12volt rail or ex ternal power supply put the amp at the top of the pile
Jun 29, 2008 | Technics SA-DX940
Receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Mar 03, 2008 | Technics SA-AX710
Over load on Technics SA-GX130
There is no easy fix for this. Your unit is power itself down to protect itself. There is an obvious short. You will need seek professional assistance.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Jan 26, 2008 | Technics SA-AX540 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
112 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
