No spin cicle - Washing Machines
WILL NOT SPINN OR DRAIN MODEL # WDSR2080D2CC
Posted on Jul 13, 2008
Model number WFK 2401UC
Posted on May 12, 2008
    Genius:
  • 1,073 Answers
What is the model number of the washer
Posted on May 11, 2008
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
My washer has a strong noise in the braket wen is in spin psae on cicle. I thin has the transmition broken.
check for wobble in spin tub only not main tub if so tub is rusted on centre post and can be replaced
big job
Jun 09, 2011 | Washing Machines
The machine stop during spin cicle
You might want to check the drive belt of your washer. There might be kinks with its belt and you should straighten it up. Also, check for signs of loose objects such as buttons and coins. These might get stuck in your washer's motor causing a malfunction in its spin cycle. Source(s): http://www.washingmachineadvisor.com
May 16, 2011 | Speed Queen Washing Machines
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
