Question about KitchenAid Professional KFP770 Food Processor
I have a kitchenaid kfpw760 food processor. I assembled it as per manual then added ingredients to work bowl, but...my ingredients are below the blade in the bowl and the blade doesn't contact the ingredients. I think its assembled wrong. I need help. Yes, I'm a guy. Thanks
  • 145 Answers
The work bowl lid has a feed tube on it, and the unit should have also come with a "feed tube pusher," a plastic piece to help depress food through the feed tube itself.
With a food processor, you will want to assemble the unit first, engage, and then add ingredients. This will ensure the ingredients fall through the blade and/or disc to be processed thoroughly.
Posted on Jul 08, 2009
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
My kitchenaid processor is not working
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Unit assembled, lights are on (pulse, on) nothing happens
Jul 19, 2009 | KitchenAid KFP740 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
I have the unit plugged in and the ingredients in the bowl, but it will not pulse...what am i doing wrong?
I am assuming that the unit is not getting any power whatsoever and this is not isolated solely to the pulse function not working.
May 10, 2009 | KitchenAid KFP740 Food Processor
Have trouble getting it to start
Mar 04, 2009 | KitchenAid KFC3300 Mini Chopper 3 Cups...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
KitchenAid Professional KFP770 Food Processor Logo
278 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
